freecad 0.19 techdraw problems with dxf
koirat
Re: freecad 0.19 techdraw problems with dxf
Post by koirat »
jmaustpc wrote: Wed Oct 06, 2021 12:52 am I just noticed this topic when approving this first post.
The error message is tell you exactly what the problem is, the exporter does not have full or any Bspline/Bcurve support yet. The solution is for one of you or someone else to write that code.
I might actually try to pull this off.
Do you have any resources that I can use.
I'm talking especially about documentation regarding exporters for Freecad and best dxf documentation.
Also what is BCurve referring to ? Is it Bezier Curves ?
Roy_043
Post by Roy_043 »
jmaustpc wrote: Wed Oct 06, 2021 12:52 am In this case I think you will find your files will work via the legacy importer/exporter, but I am not sure.
The DXF import and export preferences are not used by TechDraw_ExportPageDXF.
koirat
Post by koirat »
OK looks like legacy exporter worked for me. What are the downsides ?
Roy_043
Post by Roy_043 »
Are you sure you are exporting a TechDraw page?
koirat
Post by koirat »
I'm not exporting TechDraw but simply 2DView, but it is enough for me. It's for laser cut.
