I've seen https://forum.freecadweb.org/viewtopic.php?t=52815, which indicates that as long as a STEP file is valid, it should work in TechDraw. The attached file used Part -> Import CAD of a STEP file of a pipe cap from McMaster Carr. Checking the part shows no errors. But if a page is inserted in TechDraw, then that part is selected to create a view from, something seems to go into an endless loop and FreeCAD stops responding.
If I'm doing something wrong, holler. If not, hope this helps track a bug.
Thanks!
PS - using PartDesign and adding a body to it didn't make any difference in my trials.
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
TechDraw and STEP file
- pipeCap.FCStd
- (902.51 KiB) Downloaded 33 times
Re: TechDraw and STEP file
If I check the object with BOPCheck enabled, it shows lots of errors. Beware it may take long, I don't know how long, I let it working while going away.
I thought it did all the checks because all the individual BOP checks were checked. Newbie/interface mistake.
