Ticket #4639 - TechDraw not drawing all lines in view
Discussion thread for [bug]issue #4639[/bug]: TechDraw not drawing all lines in view
Re: Ticket #4639 - TechDraw not drawing all lines in view
It's a known issue. Turn the object very slightly, e.g. (-0.576, -0.577, 0.577).
Greetings to the Community!
In my humble opinion, an optimal workflow has not been carried out by “run_the_race”. It is well known that in several cases this way of proceeding can give rise to unexpected results: the graphics processor, in the phase of generation of the 2x20 pins (complex function of PartDesign "multiple transformation"), would have generated a calculation/render error: "error of non-intersecting faces" this is the reason for the incorrect creation of the axonometric view in TechDraw.
To overcome the apparent error generated by FC, I made the intersection, equal to 0.01 mm, of the first pin with the support surface and then the "multiple transformation" was applied.
However, I find "bizarre" the way to design (in PartDesign) as a single monolithic block different components (certainly not an optimal workflow for a parametric cad like FC) in fact if we were to modify some component of the structure we will almost certainly run into in the unresolved "topological redefinition/renaming" error.
The difference of the two flows is also appreciable in the "weight" of the two files:
- Raspberry_pi_4B_optimal_workflow = 157 KB
- Raspberry_pi_4B_single block = 419 KB
With the hope of having been exhaustive, I wish you a good evening.
- Raspberry_pi_4B_single block.FCStd
- (418.44 KiB) Downloaded 34 times
- Raspberry_pi_4B_optimal_workflow.FCStd
- (156.94 KiB) Downloaded 37 times
- optimal_workfolw.png (163.17 KiB) Viewed 1721 times
- optimal_workfolw2.png (175.48 KiB) Viewed 1721 times
- single_block.png (182.03 KiB) Viewed 1721 times
- wandererfan
This appears to be an issue with the OCC orthographic projector. If we change to the perspective projector (with a large focal length) we get a better result.
I think this has come up before, but I can't find a reference to it.
