Version 0.19 TechDraw problem
Re: Version 0.19 TechDraw problem
I just now saw that you can attach files directly...
Greetings to the Community!
I confirm, I add that it also happens for the "Balloon" function
OS: Linux Mint 20.3 (X-Cinnamon / cinnamon)
Version: 0.20.28751 (Git) AppImage
Branch: (HEAD detached at 660655e)
Hash: 660655e54c97b5017ff0ac1e030059308cd4e3f5
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
- wandererfan
Old versions set font size in points. New versions set font size in pixels. Since points are bigger than pixels, the text looks small in new versions.
A macro to adjust text size for annotations, balloons and dimensions is here: https://github.com/FreeCAD/FreeCAD-macr ... 18.FCMacro
Isn't it possible to handle the conversion factor internally so that the Text Size property value matches the actual size?
- wandererfan
Not really. Two different fonts in the same nominal size can have very different sized glyphs. You'd have to measure the actual font to get an exact conversion factor.
@wandererfan Thanks for your macro.
By the way: The templates are correct if you save the file and open it again...
Do I understand correctly that the problem will not be solved in the future either. So if I want 7mm text, do I have to enter 9.33mm!?wandererfan wrote: ↑Tue Apr 26, 2022 11:38 pm Not really. Two different fonts in the same nominal size can have very different sized glyphs. You'd have to measure the actual font to get an exact conversion factor.
- wandererfan
If you are using v018, then yes. If you are using v019 or v020, then it depends on how you measure the text and what font you are using. If you want the tallest glyph to be exactly 10mm, you will have to fiddle. If you are content with the usual bit of blank space above and/or below text, then you can just specify the height in mm.
The grid in the picture is 10mm. So if you want the "b" in "Ubuntu" to be exactly 10mm high, you will have to specify 12mm text. For a different font, it might be a different number.
- fontSizesv020.png (28.53 KiB) Viewed 1131 times
Too bad.
Maybe the bug or the feature will be fixed in one of the next versions, that like in version 0.18 a 5mm text is also 5mm high.
Hi.
Allow me to speak in the discussion.
The issue requires the establishment of specific criteria - at least, we need to determine how to define font size.
Let's assume that the font matrix consists of pixels of 8x4 layout (8 is the height). With such an assumption one has to pay attention that for example the letter b does not occupy the whole font matrix, neither does the letter o or the letter y.
So you need to establish a rule for dimensioning the font when specifying its length. And you have to do it so that it is communicative for the user.
Since it is about the creation of technical plans, the definition is easy in my opinion. If I create a lettering by hand, I use a 5mm stencil and then the lettering is 5mm high (refers to capital letters e.g. H). Fortunately, this also works in 0.18, which I continue to use.
