TechDraw Section line not centered
MAMINE
Post by MAMINE »
As shown on attached screenshot, the section line (A-A) is not centered to the base view (FreeCAD file is also attached)
The section line cannot either move by mouse nor by any other parameter of the base view or the section view
any solution ?
OS: Ubuntu 20.04.2 LTS
Version: 0.19.
Branch: unknown
Hash: 9e3b630bbfb6807e93eeffb655e6c20f218644fc
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
P01.FCStd
(139.7 KiB) Downloaded 49 times
Re: TechDraw Section line not centered
Upload the file for help on a solution.
MAMINE
Post by MAMINE »
I attached the FreeCAD file (see first post).
domad
Post by domad »
MAMINE wrote: Tue Jun 08, 2021 2:48 pm .........
Hello!
Just double click on "Section A-A" in the structure panel.
I can confirm the issue - even if I remove the last fillet which shows errors here, and even if I remove the unnecessary Part container.
MAMINE
Post by MAMINE »
domad wrote: Tue Jun 08, 2021 5:53 pm Just double click on "Section A-A" in the structure panel.
this did nothing.
I think the issue is caused by wrong view center calculation. As you can see on screenshot, when "Horizontal Center Line" is activated, the supposed center line is offset; just like the section line.
Update,
The base view (even when deleting the section section view) has an offset center line (it is has circular shape generated by PartDesign Revolve feature), this seems related to the section line issue (see screenshot).
You are right, although I think that the desired center cannot always be calculated. The problem seems to be that changung the y-value does nothing. If you make a horizontal cut, you can see that the section is off center as well, but changing y to 0 does the job. This should work for vertical cuts as well.
domad
Post by domad »
MAMINE wrote: Tue Jun 08, 2021 6:40 pm ............
I apologize for not having carefully analyzed the problem (I had not noticed in my first reply the "Y" shift in TD of the reference to the section).
It is always advisable to reduce the modeling operations, therefore, if a fillet and / or chamfer can be inserted in the sketches it is always the preferred thing.
P01-2.FCStd
(130.1 KiB) Downloaded 48 times
Shalmeneser
Post by Shalmeneser »
Page : ProjGroup : Data : Source : fillet => bad center line
Page : ProjGroup : Data : Source : PolarPattern => correct center line
The problem is coming from the fillet.
Shalmeneser
1) Hole + Cut 1 dimension + PolarPattern ×4 (P01)
2) Hole + Cut 2 dimensions + PolarPattern ×2 (P01-2)
Which one is better ?
It's the 1st time i see diameter dimension for a revolution (with a symmetrical point).
Why not Radius=Diameter/2 ?
@Domad
How do you do the 6,604 circle in techdraw ?
160° ?
