Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
- babaroga
- Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Re: Macro version 4.2 multilanguage: helper tools to improve TechDraw documents.
It will mean a lot, if there is something like isChildOf() property in pattern or mirror so you can trace back to original.
First of all: Thank you very much for this great tool! I'm trying it out right now and I really appreciate it. I've found two things which didn't work as expected. In addition, I've some more questions and wishes
chamfers
This one was already reported by Shalmeneser and apparently you've already worked on it. Nevertheless, I think it's not yet perfect.
changing line attributes
I assumed it would be enough to select any line and select one of the colors to change the color of the selected line. But nothing is happening here. What am I doing wrong?
edit: Clicking on "change the line attributes" doesn't work and gives me something like this:
dimension symbol
Great that I'm now able to add the dimension symbol without copying it from the internet / looking up the UTF8-code But I've discovered that I'm not able to apply it to all kind of dimensions. It's not working with TechDraw_HorizontalExtentDimension and https://wiki.freecadweb.org/TechDraw_Ve ... tDimension.
example file for both cases:
feature request
I'd like to be able to center the "number" showing the value of a dimension at a (for example) horizontal dimension. I think that's the initial state after adding a dimension.
Wiki entry
I think this macro is missing here: Macros_recipes
chamfers
Shalmeneser wrote: ↑Sat Jul 10, 2021 8:29 pm Why the vertical and horizontal bevel dimensions are not the same for the angle ? (done with PartDesign_Chamfer : one dimension 1 mm)
The attached example shows this behavior:
22:01:57 DVPPI::getCenterLinebySelection - centerLine for tag Edge8 not found
22:01:57 DVPPI::getCosmeticEdgebySelection - edge for name Edge8 not found
dimension symbol
feature request
Wiki entry
Regards / Viele Grüße
Max
Max
Replace in line 4387 "int" by "round"
Alpha = str(round(math.degrees(abs(math.atan(Dx/Dy)))))
Alpha = str(round(math.degrees(abs(math.atan(Dy/Dx)))))
Extend line 2646 to
if Elem.Object.TypeId == 'TechDraw::DrawViewDimension' or Elem.Object.TypeId == 'TechDraw::DrawViewDimExtent':
First select the attributes (type, line thickness, color).
If you create a new line using the macro (circle centerline, cosmetic thread etc.) it receives the selected attributes.
If you select existing cosmetic lines and press the "Change the line attributes" button, the lines change to the selected attributes.
It is easy to realize this in python, but it will be difficult to handle it. Before manipulating any measure you have to select it. Only the measure value (number) can be selected. If you select it using the curser you usually move it a little bit (without aim). Therefore the positioning and cascading tools keep the position of the number. A solution could be to have an optional choice keep/center when using the position and cascade tools.
OK, good idea I will try to do this.
Greetings to the Community!
.... two examples of how the corrections made to the code work
- Example_1_corrections_made.gif (400.48 KiB) Viewed 6875 times
- Example_2_corrections_made.gif (320.5 KiB) Viewed 6875 times
Doneedi wrote: ↑Sun Sep 19, 2021 12:20 pm Please have a look at https://forum.freecadweb.org/viewtopic.php?f=35&t=59334.
Would be fine if somebody could translate into russian language.
Sorry for not writing росси́йский.
def russianDict(self,textEnglish):
dict_ = {"Attributes and Modifications":"Свойства и модификации",\
"Centerlines and Threading":"Осевые линии и резьбы",\
"Dimensions":"Размеры",\
"Line attributes:":"Свойства линий:",\
"Cascade spacing:":"Значение интервала:",\
"Quit":"Выход",\
"set lines to ":"установить тип линий ",\
"solid":"сплошная",\
"dashed":"пунктирная",\
"dotted":"точечная",\
"dashdot":"штрихпунктирная",\
"set lines width to ":"установить толщину линий ",\
"thick 0,70":"толстая 0,70",\
"middle 0,35":"средняя 0,35",\
"thin 0,18":"тонкая 0,18",\
"set lines color to ":"установить цвет линий ",\
"black":"черный",\
"grey":"серый",\
"red":"красный",\
"green":"зеленый",\
"blue":"синий",\
"magenta":"пурпурный",\
"cyan":"голубой",\
"yellow":"желтый"}
return dict_.get(textEnglish,textEnglish)
UPD 2. Fully Completed
-------------174
"Quit":"Выход",\
"dashdot":"осевая",\
"black":"черный",\
"grey":"серый",\
"red":"красный",\
"green":"зеленый",\
"blue":"синий",\
"cyan":"голубой",\
"yellow":"желтый"}
----------------797
def textEnglish(self):
buttonText = "Рисовать линии центра окружности"
helpText = "Рисовать линии центра окружности:"+ "\n"\
"- выберите свойства линии"+ "\n"\
"- выберите несколько окружностей или дуг"+ "\n"\
"- нажмите эту кнопку"
return(buttonText,helpText)
-------------1147
buttonText = "Рисовать окружность центров отверстий"
helpText = "Рисовать окружность центров отверстий:"+ "\n"\
"- выберите не менее 3-х отверстий, лежащих на одной окружности"+ "\n"\
-------------1300
buttonText = "Рисовать осевую линию"
helpText = "Рисовать осевую линию по двум линиям:"+ "\n"\
"- выберите две линии"+ "\n"\
-------------1566
buttonText = "Обозначение резьбы отверстия в плане"
helpText = "Обозначить резьбу отверстия в плане:"+ "\n"\
"- выберите несколько окружностей"+ "\n"\
-------------1883
buttonText = "Обозначение резьбы вала в плане"
helpText = "Обозначить резьбу болта, штифта, вала в плане:"+ "\n"\
"- выберите окружности, обозначающие болт, штифт, вал"+ "\n"\
-------------2011
buttonText = "Обозначение резьбы на виде сбоку"
helpText = "Рисовать обозначение резьбы на виде сбоку:"+ "\n"\
"- выберите две параллельные линии"+ "\n"\
-------------2136
buttonText = "Обозначение резьбы вала на виде сбоку либо разрезе"
helpText = "Обозначить резьбу болта, штифта, вала на виде сбоку либо разрезе:"+ "\n"\
"- выберите две параллельные линии, обозначающие резьбовую часть болта, штифта, вала"+ "\n"\
-------------2290
buttonText = "Создать точки на пересечении"
helpText = "Создать точки на пересечении линий:"+ "\n"\
"- выберите две линии, окружности, дуги"+ "\n"\
-------------2449
buttonText = "Изменить свойства линий"
helpText = "Изменить свойства выбранных линий:"+ "\n"\
"- выберите несколько тонких или штрихпунктирных линий"+ "\n"\
-------------2582
buttonText = "Вставить знак 'Ø'"
helpText = "Вставить знак 'Ø' в размер:"+ "\n"\
"- выберите несколько размеров"+ "\n"\
-------------2705
buttonText = "Вставить знак '〼'"
helpText = "Вставить знак '〼' в размер:"+ "\n"\
-------------2821
buttonText = "Группа ортогональных проекций: установка линии разреза"
helpText = "Установить линию разреза на оси X или Y базового вида"+ "\n"\
"- выберите направление разреза"+ "\n"\
-------------2956
buttonText = "Блокировать (разблокировать) вид
helpText = "Блокировать (разблокировать) вид"+ "\n"\
"- выберите вид"+ "\n"\
-------------3068
buttonText = "Создать вертикальную цепь размеров"
helpText = "- выберите не менее трех точек"+ "\n"\
-------------3186
buttonText = "Создать горизонтальную цепь размеров"
-------------3308
buttonText = "Расположение вертикальной цепи размеров"
helpText = "Располагает выбранные вертикальные размеры на одной линии:"+ "\n"\
"- выберите два и более размера"+"\n"\
-------------3426
helpText = "Располагает выбранные горизонтальные размеры на одной линии:"+ "\n"\
-------------3552
buttonText = "Вертикальные размеры"
helpText = "Величина горизонтального интервала между выбранными размерами:"+ "\n"\
"- выберите величину интервала"+ "\n"\
"- выберите два и более вертикальных размера"+ "\n"\
-------------3685
buttonText = "Горизонтальные размеры"
helpText = "Величина вертикального интервала между выбранными размерами:"+ "\n"\
"- выберите две и более горизонтальных размера"+ "\n"\
-------------3811
buttonText = "Добавить разряд (max 9)"
helpText = "Добавляет разряд:"+ "\n"\
-------------3937
buttonText = "Убрать разряд"
helpText = "Убирает разряд:"+ "\n"\
-------------4058
buttonText = "Создать горизонтальные координатные размеры"
helpText = "- выберите величину интервала"+ "\n"\
"- выберите три и более точки"+ "\n"\
-------------4184
buttonText = "Создать вертикальные координатные размеры"
-------------4320
buttonText = "Горизонтальный размер фаски"
helpText = "- выберите две точки"+ "\n"\
-------------4441
buttonText = "Вертикальный размер фаски"
-------------4558
buttonText = "Создать массив отверстий"
helpText = "- выберите точку отсчета"+ "\n"\
"- выберите несколько отверстий"+ "\n"\
-------------4743
buttonText = "Рисовать вспомогательную окружность (по центру и точке)"
helpText = "Рисовать вспомогательную окружность по двум точкам:"+ "\n"\
"- выберите свойства линии:"+ "\n"\
"- укажите центральную точку) -> затем укажите вторую (радиус)"+ "\n"\
-------------5019
buttonText = "Рисовать вспомогательную дугу (по центру и двум точкам)"
helpText = "Рисовать дугу в положительном направлении:"+ "\n"\
"- выберите три точки:"+ "\n"\
"- центр, начало, конец"+ "\n"\
"- задайте радиус"+ "\n"\
-------------5173
buttonText = "Продлить линию"
helpText = "Продлить линию с обоих концов:"+ "\n"\
"- выберите одну тонкую или осевую линию"+ "\n"\
-------------5288
buttonText = "Укоротить линию"
helpText = "Укоротить линию с обоих концов:"+ "\n"\
-------------5415
buttonText = "Создать развертку/длину дуги"
helpText = "Укажите развертку / длину дуги с помощью символа '∩':"+ "\n"\
"- выберите одну дугу"+ "\n"\
-------------5545
buttonText = "Создать перпендикулярную линию"
helpText = "Создать перпендикулярную линию через точку "+ "\n"\
"- выберите одну линию"+ "\n"\
"- выберите одну точку"+ "\n"\
With best regards.
I've just discovered that I'm not able to add the dimension symbol to TechDraw_HorizontalExtentDimension. It works very well with TechDraw_HorizontalDimension.
TechDrawTools v 0.4.4
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25943 (Git) AppImage
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
- TDTools_Diameter_Symbol_DimExtent_M4x.FCStd
- (17 KiB) Downloaded 101 times
Max
Max
Hello
Open the macro in FC and look for the line (it should be 2643) starting with:
def activated(self):
DiamSign ='Ø'
if Elem.Object.TypeId == 'TechDraw::DrawViewDimExtent' or 'TechDraw::DrawViewDimension':
Elem.Object.FormatSpec = DiamSign+OldFormat
DiamSign ='Ø'
Sel = gui.Selection.getSelectionEx()
for Elem in Sel:
OldFormat = Elem.Object.FormatSpec
A greeting
- TDTools_Diameter_Symbol_DimExtent_M4x.gif (289.63 KiB) Viewed 5830 times
That makes sense. Thank you!
Max
Max
Since there have been several questions, here's how you can quote (with a little patience, but not a lot) a plane axonometry in TechDraw using the tools of the "TechDrawTools V-0.4.4 multilanguage" macro.
For those wishing to try their hand at completing the sizing, acquiring practicality, in attachment, the Basic_Part_Design_Tutorial.fcstd "(revised) file used as a base.
- Isometric_axonometry_dimensioning.png (193.29 KiB) Viewed 4297 times
- Basic_Part_Design_Tutorial.fcstd
- (139.48 KiB) Downloaded 90 times
- axonometry_dimensioning.gif (880.94 KiB) Viewed 4297 times
