[bug] Tech Draw → Add Centerline to Faces (component)
Hello.
While checking the quality of TechDraw WB translations, I found an error.
Close the tools :
Add Centerline between 2 Lines
Add Centerline between 2 Points
with the cancel button, deletes the drawing view.
Can anyone confirm this?
Close the tools :
Re: [bug] Tech Draw → Add Centerline to Faces (component)
I cannot confirm. Did you initiate this while having another dialog open?
OS: macOS 10.16
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Hi.
I have included a link to the video in my next post, which also covers this case.
https://forum.freecadweb.org/viewtopic. ... 35&t=59529
Did you have the opportunity to watch my presentation
Watch the video from the 3rd minute.
A link to the version of FC I am using is also included in the post.
That's what I had done here with no crash. You should add your full FreeCD infos here.
ok.
But I also replicate this information here.
I distinguished the link to this information in the first post.
OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma)
Version: 0.20.25065 (Git) AppImage
Qt version: 5.12.9
OCC version: 7.5.2
Locale: Polish/Poland (pl_PL)
In such a case it is sensible to replicate the FreeCAD infos, because a developer will recognize them at a glance. If it is hidden behind a link the contents have to be read in much more detail.
If there is anything else I can do to help identify the error let me know.
You can simplify the model as far as possible, e.g. by using just a default Part cube and upload it. Even if it is simple to rebuild, it is still easier to download a model where only two points have to be selected, and a centerline is to be cancelled.
Can confirm OP's deletes the view on cancel.
Now if instead of cancel you hit Undo the cosmetic line remains. Think that was also in OP's video.
Catch is the cosmetic line has no properties thus undo can't undo it. You have to click on line and use Eraser button.
Here is link look under properties
https://wiki.freecadweb.org/TechDraw_2PointCosmeticLine
Edit: posted before FCInfo
OS: Ubuntu 20.04.2 LTS (MATE/mate)
Qt version: 5.12.9
OCC version: 7.5.2
Included file and gif
Qt version: 5.12.9
OCC version: 7.5.2
- cl1.gif (469.29 KiB) Viewed 1849 times
- cl1.FCStd
- (12.73 KiB) Downloaded 45 times
No problem.
here are the test project files: one from the Part environment and the other from Part Design.
The error occurs here and here. I tested on the cosmetic vertex.
I remind that when I use other tools (from other group) the problem does not occur.
And here is my project for testing.
