[FIXED] Tech Draw → undo button
Hello.
While checking the quality of TechDraw WB translations, I found an error. (yet another)
When using the tools from the TechDraw annotation toolbar, and using the undo button, the view drawing is deleted.
I don't think this is how it is supposed to work ...
https://vimeo.com/564764403
Can anyone confirm this?
Re: [bug} Tech Draw → undo button
There are errors appearing in the report view on your video but quality is too low to read this. Moreover as it isn't in English, I doubt I can understand what is reported. Could you give details about that ?
It's just the way the module is coded. Plenty of posts stating after creating a cosmetic item to delete you have to click on it and use the eraser tool.
AFIK it was not programmed in manner that undo was aware of the cosmetic additions.
Also you discussed basically the same questions in
https://forum.freecadweb.org/viewtopic.php?f=35&t=59527
If you want you can code a fix and submit a PR.
Well, that's where the problem lies.
agreedmendy wrote: ↑Wed Jun 23, 2021 11:44 am Also you discussed basically the same questions in
Prepared video has no narration. I made them on short notice.
Yes, the program interface is in Polish, but the positions of all options are identical in other languages.
If you are interested in details, ask a specific question, I will answer you in detail.
I checked the source code and the Undo/Redo was really not implemented for Cosmetic Vertices and Lines. Fortunately, the fix is quite easy, so I have created Pull Request #4895 to add the functionality.
If you would encounter any problems or have any suggestions for changes/improvements, please let me know.
Kind regards,
Tomas
Kind regards,
Tomas
With your involvement you have made me very happy.
There is a second topic with a related error. https://forum.freecadweb.org/viewtopic. ... 35&t=59527
I don't know if you looked at it.
Thank you for your work for the entire FreeCAD community.
My sincere greetings to you.
Kind regards,
Tomas
I was playing with the center lines and undo/redo seems to work fine, the only problem was the view not getting updated once one presses the button. Nevertheless, this should be fixed by the pull request as well.kaktus wrote: ↑Mon Jun 28, 2021 4:52 pm There is a second topic with a related error. https://forum.freecadweb.org/viewtopic. ... 35&t=59527
Kind regards,
Tomas
You are amazing.
Thank you.
tpavlicek wrote: ↑Mon Jun 28, 2021 1:55 pm Hi,
Kind regards,
Tomas
Hi @tpavlicek.
Your PR has been implemented. And the undesirable effect of the model disappearing when using the undo redo stack no longer exists.
Thank you for your contribution.
However, there is still an unsolved problem of the model disappearing when closing the tool window (task panel) with the cancel button.
Applies to tools :
Create Center Line
Add Centerline between 2 Lines
Add Centerline between 2 Points
Will you be able to take a look at it
- wandererfan
I can't duplicate "the model disappearing". Can you provide step by step instructions please?
I did notice an issue with multiple centerlines when canceling an edit of 1 line, all the centerlines are removed.
