is there a way that i can export a dxf with the hatch pattern.
The causes of this are as follows:
- Tech Draw is nice but it took a lot of time to make technical drawings
Technical Drawings for Assemblys not quite there where it should be
GD&T to create is very time consuming
I tried to make this workflow with exporting Stp Files and make the drawing in a comercial Cad System but the problem is that when some changes are made the whole drawing work must be done again. With exporting a dxf file the dimensions are still there and i can make the rough drawings in techdraw and finish it in for example TurboCad without to make the basic dimension drawings again when the model has changed a little bit.
thanks
