[Solved] 'TechDrawGui.MDIViewPage' object has no attribute 'getViewer'
Evgeniy
Post by Evgeniy »
This error appears when trying to Export current page to SVG file. What can it be caused by?
'Template001': no Shape, calculate manual bounding box
File "<string>", line 4, in <module>
File "M:\FreeCAD_0.20.25645_Win-LPv12.5.4_vc17.x-x86-64\Mod\Draft\importSVG.py", line 1824, in export
bb.add(Draft.get_bbox(obj))
File "M:\FreeCAD_0.20.25645_Win-LPv12.5.4_vc17.x-x86-64\Mod\Draft\draftutils\gui_utils.py", line 731, in get_bbox
region = view.getViewer().getSoRenderManager().getViewportRegion()
<class 'AttributeError'>: 'TechDrawGui.MDIViewPage' object has no attribute 'getViewer'
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Founder
Re: 'TechDrawGui.MDIViewPage' object has no attribute 'getViewer'
Post by wmayer »
The SVG file format from the global Export function is supposed to work for Draft objects only. TechDraw has its own SVG (and DXF) exporter that you can find in the toolbar or in the Tech Draw menu.
Maybe for the future it would be good to make things more flexible and support to export TechDraw objects with the Draft SVG exporter.
Evgeniy
Post by Evgeniy »
Export from TechDraw Workbench is works fine.
wmayer wrote: Sat Sep 18, 2021 6:23 am Maybe for the future it would be good to make things more flexible and support to export TechDraw objects with the Draft SVG exporter.
I think, this is certainly not critical yet.
But messagebox recommending the use of export from TechDraw would not hurt.
