[SOLVED] 〼 -> What does this symbol stand for?
Evgeniy
Re: [SOLVED] 〼 -> What does this symbol stand for?
Post by Evgeniy »
It is probably better to use a combo box for these characters (at least). Or string of buttons for fast insert. But it's worth thinking about everything well.
It will not be possible to do it perfectly right away in any case
What characters are used in ISO?
Do specify the number of holes in the dimensions in ISO?
What special symbols used in ISO?
In GOST (perhaps this is an incomplete list):
Before dimension:
отв. Ø - Diameter with number of holes (5 отв. Ø35) = 5 holes with diameter 35 mm.
Ø - Diameter symbol
□ - Rectangle shape size (Rectangle symbol without line inside) (□ 30)
○ or ⭘- Sphere shape diameter (⭘ Ø32)
⊲ - Conic shape left to right (⊲ 1:5)
⊳ - Conic shape right to left
⦣ - Draft of surface (Symbol looks ugly, but I didn't find anything else in unicode) (⦣ 1:100 ; ⦣ 12% ; 5 ‰)
⦟ - Draft surface other direction.
° - grad may be used for angles
After dimension:
x 45° - for chamfer
I would like to note that osifont is a little unfinished and has errors.
Does the license allow us to modify this font?
Do we have the right to add beautiful symbols of these characters to this font? For example in Unicode Private Use Area.
Evgeniy
Post by Evgeniy »
My vision of this feature is insert from combobox selection:
Pyhthon scripts:
Macro.zip
(1.13 KiB) Downloaded 44 times
Inserter code logic (for example):
percent, grad and chamfer info, can be inserted at end of string.
other symbols can be inserted at start of string.
   if "45" in sel:
      form.field.setText(form.field.text()+" "+sel)
   elif sel=="°" or sel=="‰":
      form.field.setText(form.field.text()+sel)
   else:
      form.field.setText(sel+form.field.text())
Theoretically, all the characters combinations can be packed into a single string as:
fmstr = "Ø*;□*;⭘*;⊲ *;⊳ *;⦣ *;⦟ *;*°; отв. Ø*;* x45°;*‰;"
Can you insert them at cursor position?
Evgeniy
Post by Evgeniy »
This can be done, but the code will still be written in C and not in Python (not by me. Only if edi decides to do so). This is just a representation of how it can work.
Evgeniy
Post by Evgeniy »
Final version. What it might look like.
If the user has not clicked on the text field, the symbol is inserted either before or after the text (depending on the template).
If the user clicked on LineText, therefore he specified the cursor position, after that symbol will be inserted at the specified cursor position.
Macro3.zip
(1.48 KiB) Downloaded 37 times
#! python
# -*- coding: utf-8 -*-
import os
focus = False;
def cur_pos_changed():
   global focus
   if form.field.hasFocus():
      focus = True; print("cursor position changed and focus on QLineText, this is mean user is click on QLineText")
def cb_changed():
   global focus,symbol
   template = form.comboBox.currentText()
   item = form.comboBox.currentIndex()-1
   if item==-1:
      return    # If the user called an empty option, ignore it.
   index = form.field.cursorPosition()
   if focus:
      form.field.insert(template)   # if user set cursor position insert text to cursor position
   else:
      template = symbol[item]
      if "*" in template:
         form.field.setText(template.replace("*",form.field.text()))
      else:
         form.field.setCursorPosition(0)
         form.field.insert(template.replace("*",""))
   form.comboBox.setCurrentIndex(0) #Reset index to zero! Otherwise, when you click again, event does not work.
#form = FreeCADGui.PySideUic.loadUi(FreeCAD.getUserMacroDir()+"\Test.ui")
UiPath = os.path.join(os.path.dirname(os.path.abspath(__file__)),"Test.ui")
form = FreeCADGui.PySideUic.loadUi(UiPath)
# Add empty item at first
form.comboBox.addItem("")
# "*" is indicates where the value should be inserted
symbol_str = "Ø;□;⭘;⊲ ;⊳ ;⦣ ;⦟ ;*°; отв. Ø;* x45°;*‰"
symbol = symbol_str.split(";")
for s in symbol:
   print(s,end=";")
   form.comboBox.addItem(s.replace("*","").strip())
form.comboBox.currentTextChanged.connect(cb_changed)
form.field.cursorPositionChanged.connect(cur_pos_changed)
form.show()
edi
Post by edi »
Very interesting suggestion, thank you @Evgeniy.
The main criterion is how the user is working.
I think, the most often situation is the following:
there are many, lets say 5 measures where you want to add a diameter sign. In TechDrawTools you select the 5 measures, then click the tool icon. You need 6 clicks. No window where you have to select anything.
TechDrawTools is programmed modular. You need only copy and paste to add more tools adding other letters.
In C++ the best user interface will be cascaded icons, like used at the "insert horizontal/vertical extended dimension" command. Many icons, each creating another letter, can be cascaded. Each icon will work like in TechDrawTools.
Evgeniy
Post by Evgeniy »
In fact, instead of the digits "250" in QLineText, it should have been "%.0f" But I did not specify this point. It's easier to see.
edi wrote: Fri Sep 24, 2021 1:33 pm In C++ the best user interface will be cascaded icons, like used at the "insert horizontal/vertical extended dimension" command. Many icons, each creating another letter, can be cascaded. Each icon will work like in TechDrawTools.
If you tell about droppind list of command. I'm not sure that making a new button for each icon is a good idea.
But I'm not a developer, it's not up to me to decide.
As for the drop-down list of buttons, it seems to me like this:
Dimension list.png (28.55 KiB) Viewed 1614 times
However, probably no one will want to implement the GOST dimension type.
This is for the near future.
But in the distant future it will be possible to make separate sets of buttons for each standard.
Is one set of buttons for ISO, another for ASME, another for GOST, etc.
Drawing how it will look will take a lot of time, so I will not do this.
And in general, probably we need to create a separate topic about improve TechDraw.
