Anyone has the hatching pattern in svg for "insulation" layer?
ragohix769
Re: Anyone has the hatching pattern in svg for "insulation" layer?
Post by ragohix769 »
Roy_043 wrote: Wed Sep 22, 2021 7:29 am In your example you have an L shape that is a single contour both for a Draft hatch and a TD hatch. For the insulation pattern this contour needs to be split into two contours. Each has to be hatched separately, with a scale and angle derived from the contour.
I don't understand because I don't know the implementation of the hatching tool (in Draft and/or in TD).
But, if I undestand, in TD you can insert an hatch pattern in 2 ways: one it's geometrical/vectorial, so when you create a pdf or a dxf export, there it's all vector, hatching too. So I imagine that it's more difficult. The second way it's with Hatching "image" in TD (when you export, there is not a vector, but an Image of the pattern projected over): maybe (just for now) this is easier to manage then the vectorial method?
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough :-(
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same :-)
Roy_043
Post by Roy_043 »
I have corrected my previous message. Some PAT patterns with dashed lines do work.
ragohix769
Roy_043 wrote: Wed Sep 22, 2021 9:05 am I have corrected my previous message. Some PAT patterns with dashed lines do work.
Have you the PAT file with the pattern to share?
[in general: how it's possibile to create *.PAT files? they are *.svg that can be created with Inkscape?]
Roy_043
Post by Roy_043 »
PAT files are text files. There are some utilities to create them out there, but they usually require a DwgCAD program to run. You can also create them manually.
The honeycomb pattern in my previous example belongs to a commercial DwgCAD program, so I don't want to post that.
Attached is a FCPAT.pat file with a new pattern: "Insulation-ZigZag", and a FreeCAD file that uses it. Apart from the already mentioned scale and angle there is also the hatch origin that must be user defined for this pattern and the S-shaped insulation pattern to work.
Note: The scale of the Insulation-ZigZag pattern must equal the scaled thickness of the insulation.
insul-zigzag.FCStd
(10.11 KiB) Downloaded 46 times
FCPAT.zip
(344 Bytes) Downloaded 45 times
ragohix769
That's very strange: now if I push over "apply geometric Hatch to face" in Td, FC crash (not exit but not responding anymore).
But if I use "Hatch a Face using image file", it's still working as usual.
OS: Ubuntu 18.04.6 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: 582c26ea8b5f9d85957a6cb1bf798839fa2ce94c
Python version: 3.6.9
Qt version: 5.9.5
OCC version: 7.5.2
Locale: Italian/Italy (it_IT)
