No centers, not what you all think.
Chia_Pet
Re: No centers, not what you all think.
Post by Chia_Pet »
Nope Didn't Work for me. Must be bug in A2plus?
user1234
Post by user1234 »
Did you recompute the drawing after the change?
edit: also please give the FreeCAD infos. my are:
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.25829 (Git)
Hash: 5d4f7e96b4fba586186a722925c3f4cd0340533d
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.3
Chia_Pet
Post by Chia_Pet »
user1234 wrote: Fri Sep 24, 2021 5:47 pm Did you recompute the drawing after the change?
yep, every which way possible.
Chia_Pet
Post by Chia_Pet »
Qt version: 5.15.2
OCC version: 7.5.3
put it on original post
user1234
Post by user1234 »
Sorry, overseen that.
I installed A2+ and this works as i said, see video.
0.webm
(83.5 KiB) Downloaded 32 times
Seem to be a bug in 0.19 which is solved in 0.20master. But i am sure that the developers will not backport this. Sorry.
Greetings
user1234
Chia_Pet
Post by Chia_Pet »
user1234 wrote: Fri Sep 24, 2021 6:03 pm Sorry, overseen that.
I installed A2+ and this works as i said, see video.0.webm
Greetings
user1234
How Do i get .20 Master?
user1234
Post by user1234 »
See https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds. But before you change that, you can not go back if you make a change in the files and save that (no backwards compatibility). Also there are very rare incompatibilities, especially with the settings.
So make a backup for your files. Also, at least i make this, on every version i run FreeCAD, i set a own configuration path so the versions do not cross their settings, see https://wiki.freecadweb.org/Start_up_and_Configuration.
My start command is
<path_to_the_binary>  --log-file /home/username/.FreeCADmaster/FreeCAD.log --user-cfg /home/username/.FreeCADmaster/user.cfg
. So i give the standard settings for the master always a master remark. But note, i am on Debian, i do not know how it looks like on windows, but i am pretty sure it is pretty similar.
Greetings and good luck!
user1234
