No centers, not what you all think.
Chia_Pet
Post by Chia_Pet »
So Im trying to add multiple parts to the same Page sheet.
a single Part works fine, all my centers show up etc.
but here's the problem.
If I make view from an assembly (A2plus V.4.54b), and pick the original part brought into the assembly first, it shows the centers for holes.
If I then bring in another part, the centers are gone. For that part only.
If I have say 3 parts in my assembly. I then activate all three parts and hit "insert a view" All three parts will show up in one view, but only original part will have centers, other 2 will not.
anyone got any idea how to fix this?
I'm trying to get multiple small parts on one Page, not make a Page for each Part which is a waste of time.
Edit for clarity:
Tech draw preferences: Show Center Marks and Print Center Marks = Checked
View tab: Arc centers = true
Edit All relevant Files Attached
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Mae West Operator Side Entry Top Shim.FCStd
(21.88 KiB) Downloaded 33 times
Mae West Operator Side Entry Shim.FCStd
(46.67 KiB) Downloaded 31 times
Mae West Operator Side Entry Bottom Shim.FCStd
(21.68 KiB) Downloaded 35 times
Assembly Test for Freecad Unconstrained.FCStd
(27.87 KiB) Downloaded 33 times
Assembly Test for Freecad Constrained.FCStd
(30.8 KiB) Downloaded 36 times
Re: No centers, not what you all think.
Is ArcCenterMarks=True for all views? You find it in the View properties.
Chia_Pet
Post by Chia_Pet »
Yep.
Some of them may be recognized as ellipses. Can you check that? You can select the circle and create a diameter dimension. If it is an ellipse you will see a corresponding message.
Chia_Pet
Post by Chia_Pet »
So yes, that is happening.
so this is what i did this morning.
opened up the 3 parts in an assembly.
no constraints, just placed by hand.
Created a page, picked the parts, they came in fine and had centers.
Because the parts were not all "face up", I then constrained the parts to the Part that was face up.
I constrained them first with a Plane coincident to the Face of first part, effectively flipping the part and ensuring all parts are on exact same plane.
I then did 2 more similar constraints ensuring they were perpendicular to the first part and on same planes as well so parts are fully constrained in X, Y, and Z.
I then update view in Techdraw, and the 2 other parts lose their centers, and get the ellipse you stated.
Chia_Pet
Post by Chia_Pet »
Next thing i did, was to add the parts in new and position them solely with Transform tool.
This corrected my current issue, however, the problem persists with constrained parts, meaning it will rear its head with any actual Page with multiple parts combined into a whole.
user1234
Post by user1234 »
Hello!
Chia_Pet wrote: Fri Sep 24, 2021 3:13 pm problem persists with constrained parts
Without a file nobody is able to help.
Greetings
user1234
Chia_Pet
Post by Chia_Pet »
user1234 wrote: Fri Sep 24, 2021 3:22 pm Hello!
Greetings
user1234
There ya go!
user1234
Post by user1234 »
So, ez, no joke, not easy, but tricky one.
I thought this, but i want not make a guess in the blue. The positions are not precise enough. When i look in the directions of the parts, there is a minus before the zero, this means it is not zero, so the parts are a little bit twistet. When i correct them per hand, the marks appear.
before:
after:
note: i have not the assembly add-on, so my tree looks a little bit different.
Greetings
user1234
Chia_Pet
Post by Chia_Pet »
Very Interesting, great find, Ill try that.
Thank you
Nopers, No worky
