[Issue #4755] Copying a section view segfaults
SIXe
Post by SIXe »
When trying to copy a section view to another page, FC segfaults. Steps to reproduce:
- create simple graphic
- create TD page
- create section view
- create another TD page
- create another section view
- drag and drop the view to the ProjGroup of the 2nd page
  /tmp/.mount_FreeCAMuoQyh/AppRun: line 41: 354130 Segmentation fault      ${MAIN} "$@"
I don't know if this is not supported, but even in case it's not, FC should not segfault. Example file and screencast attached.
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.25645 (Git) AppImage
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
section_view_segfault.webm
(771.86 KiB) Downloaded 41 times
copy_section_view.FCStd
(16.1 KiB) Downloaded 41 times
Founder
Re: Copying a section view segfaults
Post by wmayer »
Confirmed. It crashes inside the function TechDrawGui::QGVPage::removeQView at line 288:
int QGVPage::removeQView(QGIView *view)
    if (view != nullptr) {
        removeQViewFromScene(view);
        delete view; // <<<=========  BOOM!!!
    return 0;
view might be a dangling pointer.
SIXe
Post by SIXe »
Thanks for confirming.
issue #4755
edit: change tag
openBrain
Post by openBrain »
SIXe wrote: Mon Sep 27, 2021 7:02 pm Thanks for confirming.
https://tracker.freecadweb.org/view.php?id=4755
Could you please :
* Use the <bug> tag instead of hard link
* Prepend the title of the thread with "[Issue #4755]"
Thx
SIXe
Post by SIXe »
openBrain wrote: Mon Sep 27, 2021 7:20 pm * Use the <bug> tag instead of hard link
done
openBrain
Post by openBrain »
SIXe wrote: Mon Sep 27, 2021 7:25 pm done
Thanks
Founder
Re: [Issue #4755] Copying a section view segfaults
Post by wmayer »
This change seems to fix the crash:
//this is time consuming. should only be used when there is a problem.
void MDIViewPage::fixOrphans(bool force)
    if(!force) {
        m_timer->start(100);
        return;
    m_timer->stop();
    // get all the DrawViews for this page, including the second level ones
    // if we ever have collections of collections, we'll need to revisit this
    TechDraw::DrawPage* thisPage = m_vpPage->getDrawPage();
    if(!thisPage->getNameInDocument())
        return;
    std::vector<App::DocumentObject*> pChildren  = thisPage->getAllViews();
    // if dv doesn't have a graphic, make one
    for (auto& dv: pChildren) {
        if (dv->isRemoving()) {
            continue;
        QGIView* qv = m_view->findQViewForDocObj(dv);
        if (qv == nullptr) {
            attachView(dv);
    // if qView doesn't have a Feature on this Page, delete it
    std::vector<QGIView*> qvss = m_view->getViews();
    std::vector<QPointer<QGIView>> qvs;
    std::for_each(qvss.begin(), qvss.end(), [&](QGIView* v){ qvs.emplace_back(v); });
    App::Document* doc = getAppDocument();
    for (auto& qv: qvs) {
        if (!qv)
            continue; // already deleted?
        App::DocumentObject* obj = doc->getObject(qv->getViewName());
        if (obj == nullptr) {
            m_view->removeQView(qv);
        } else {
            TechDraw::DrawPage* pp = qv->getViewObject()->findParentPage();
            /** avoid crash where a view might have more than one parent page
             * if the user duplicated the page without duplicating dependencies
            int numParentPages = qv->getViewObject()->countParentPages();
            if (thisPage != pp && numParentPages == 0) {
The problem is that qvss contains several items and when deleting one of them it could cause to delete a child item that is also inside qvss and this leads to the double-deletion. To fix it a QPointer is needed because it gets notified when the handled object is deleted.
Founder
Post by wmayer »
git commit 83ac792fb4 fixes the crash.
However, there is a second problem: when drag and drop the Section object to the ProjGroup001 then it suddenly jumps out of the Page001.
Drag and drop with pages behaves similar to jobs: weird things happen.
