Keep dimension positioning after editing 3D model
Hi all,
enclosed you can find a video where on a test model it is possibile to see that after changing 3D dimension, the dimension position won't change according to to the other and the dim ends in the middle of the view.
I haven't found a way to keep it relative to original position (before editing the 3D model).
Thanks for any hint
Michele
Thanks for any hint
Michele
Re: Keep dimension positioning after editing 3D model
What algorithm would you propose - keeping of course other common use cases in mind?
Well, taking inspiration from writing programs like libreoffice, each text is defined in a paragraph that has several properties, including line spacing.
So instead of linking the position of the dimension to the size of the (absolute) view, it would be appropriate to link it to the position of the (relative) edge and its positioning should be a predetermined distance and (perhaps) settable by the user.
When the user moves the dimension, the algorithm should dynamically evaluate whether the new distance falls within a multiple of the line spacing in the settings.
As long as the instantaneous value is greater than a delta, the user can position the dimension at "where he wants"; when the user "enters" the dimension in a range covered by the delta, the program should move the dimension to the new line spacing * n where n are the distance steps.
If dynamically is not possible then the algorithm should calculate the delta when the user releases the mouse button, that's the event for evaluation of the positioning of the dimension.
I don't know the structure of the program and therefore I don't know how feasible it is, but for better or worse the "smart dimensioning" of Solidworks (e.g.) works more or less like this
This is my code to automate svg generation. At the bottom you can find what I'm trying to do with the dimension positioning, but it's not a good solution, it changes with every shape.
import sys
import os
FREECAD_PATH = '//usr/lib/freecad-python3/lib' #'//usr/lib//freecad//bin'
sys.path.append(FREECAD_PATH)
import FreeCAD
import FreeCADGui
import Part
import TechDraw
FreeCADGui.showMainWindow()
mw=FreeCADGui.getMainWindow()
mw.hide()
pathToTemplate = u'/path/to/a/fcstd/file/' #thisi is a freecad file that has a 3d model (Part) and a Page (Tech draw)
templateName = 'template' #the name of the freecad file
outputFolder = u'/home/user/Desktop/'
svgFileName = 'tes.svg'
template = FreeCAD.openDocument(pathToTemplate+templateName+'.FCStd') #è il file che contiene i modelli
X1 = '300 mm'
Y1 = '400 mm'
Z1 = '30 mm'
box1 = FreeCAD.getDocument('template').getObject('Box1')
box1.Length = X1
box1.Width = Y1
box1.Height = Z1
X2 = '150 mm'
Y2 = '40 mm'
Z2 = '30 mm'
box2 = FreeCAD.getDocument('template').getObject('Box2')
box2.Length = X2
box2.Width = Y2
box2.Height = Z2
#box2
moveX1 = 150.
moveY1 = 150.
box2.Placement = FreeCAD.Placement(FreeCAD.Vector(moveX1,moveY1,0),FreeCAD.Rotation(FreeCAD.Vector(0,0,1),0))
pagina = FreeCAD.getDocument(templateName).getObject('Page')
template.recompute()
offset = 60
dx1 = float(X1.strip(" mm"))/2
dy1 = float(Y1.strip(" mm"))/2
dmvX1 = moveX1/2
dmvY1 = moveY1/2
dx2 = float(X2.strip(" mm"))/2
dy2 = float(Y2.strip(" mm"))/2
# ingombri
FreeCAD.ActiveDocument.Dimension.X = -dx1-offset*1.2
FreeCAD.ActiveDocument.Dimension.Y = 0
FreeCAD.ActiveDocument.Dimension001.X = 0
FreeCAD.ActiveDocument.Dimension001.Y = -dy1-offset
#posizioni foro1
FreeCAD.ActiveDocument.Dimension004.X = -dx1+dmvX1
FreeCAD.ActiveDocument.Dimension004.Y = -dy1+dmvY1-offset*1.7
FreeCAD.ActiveDocument.Dimension005.X = -dx1+dmvX1-offset*1.7
FreeCAD.ActiveDocument.Dimension005.Y = -dy1+dmvY1
#dimejsioni foro1
FreeCAD.ActiveDocument.Dimension002.X = 0
FreeCAD.ActiveDocument.Dimension002.Y = -dy1+dmvY1*2+dy2
FreeCAD.ActiveDocument.Dimension003.X = -dx1+dmvX1*2+dx2
FreeCAD.ActiveDocument.Dimension003.Y = 0
import TechDrawGui
TechDrawGui.exportPageAsSvg(pagina,outputFolder+svgFileName)
- template.FCStd
- the testing file
- (11.61 KiB) Downloaded 38 times
As an option it could be sensible to make the position depend on the dimensioned item. I have seen many technical drawings though, where all dimensions are lined up at the border, which seems very sensible too.
Greetings to the Community!m.cavallerin wrote: ↑Sat Dec 04, 2021 5:00 am .........
Well, do you think my proposal is a good idea for further development?
Since the positioning of the dimensions (X, Y coordinates) that are created in a view refer to the center of the view (0,0), they can refer to the dimensions (Length - Height) of the "Piano" body, setting appropriate functions in the X, Y coordinate parameters.
By changing the length and / or height of the "Piano" body, the positioning of the dimensions does not change. If we move the dimensions in a broken way in any position, just activate the “Redraw Page” command and the dimensions will be repositioned correctly automatically.
To make the functionality "universal" you should enter the "block-position dimension" parameter through the "True / False" condition, once the position of the dimension has been chosen by setting the parameter to "True" the coordinates of the dimension positioning in the view are frozen , it will be up to us, in the event of a dimensional change of the object or new relocation, to reposition them ("False" condition) and then refreeze them ("True" condition).
- template2.FCStd
- (12.17 KiB) Downloaded 32 times
- template2.gif (210.22 KiB) Viewed 2831 times
I think the issue starts here. This makes no sense. If i change an object in its length and have a section is not in the correct position anymore. The x and y coordinates should depend on its x, y z placement.
Also all here is pretty fragile because of the TNP.
Greetings
user1234
Hi thanks for the suggestion, but I can't understand all steps. Can you guide me through?domad wrote: ↑Sat Dec 04, 2021 3:50 pm Greetings to the Community!
You created a spreadsheet and...?
You made universal entering "block-position dimension" parameter through the "True / False" condition, where?
Hi m.cavallerin, greetings to the Community!m.cavallerin wrote: ↑Sun Dec 05, 2021 5:18 pm Hi thanks for the suggestion, but I can't understand all steps. Can you guide me through?
I apologize for the misunderstanding, unfortunately in the file I had attached I forgot to delete the spreadsheet I had used (to avoid triggering the "circular reference" error) to refer to the placement of dimensions at the same dimensions.
Subsequently trying, with success, to set the functions directly in the parameters of the coordinates (X, Y) for positioning the dimensions and not having found any errors, I canceled the references to the spreadsheet but, unfortunately, I forgot to delete the sheet.
Regarding the problem, I simply suggested creating a parameter (True/False) that freezes/blocks or unfreezes/unlocks, the positioning of the dimension or more generally of the dimensions in the view.
