How to set References2D of Dimensions
Aleks
Post by Aleks »
I want to create Dimensions using CosmeticVertexes.
The only way I found on how to use Dimensions in scripts is like this:
dim1.References2D=[(view1, 'Vertex1'), (view1, 'Vertex2')]
The problem I have that I dont know the names of already placed CosmeticVertexes.
My question is: How do i set References2D using a direct reference to the CosmeticVertex object?
Alternatively: How do i get the name of an existing CosmeticVertex (like 'Vertex1')?
FreeCAD als Maschinenbauer in die Konstruktion und Fertigung integrieren. Schulung buchen: www.alsado.de/freecad-schulungen
edi
Re: How to set References2D of Dimensions
Post by edi »
Select several vertexes in a view, start the script:
Selection = Gui.Selection.getSelectionEx()[0]
ObjectList = Selection.SubElementNames
print(ObjectList)
A list of strings containing the vertex names will be returned.
To create a dimension use:
import TechDraw
View = Gui.Selection.getCompleteSelection()[0]
VertexNames = Selection.SubElementNames
Vertex1 = View.getVertexBySelection(VertexNames[0])
Vertex2 = View.getVertexBySelection(VertexNames[1])
DistanceDim=TechDraw.makeDistanceDim(View,'Distance',Vertex1.Point,Vertex2.Point)
but ensure two vertexes had been selected.
