High resolution drawings in FreeCAD
Re: High resolution drawings in FreeCAD
As said before, you shouldn't rely on TechDraw. Export the dxf directly!
I see. I will do some experiments.
This works out very well:
- edit the sketch
- select the parabola
- "Convert geometry to B-spline"
- export the sketch as dxf
After import it shows a smooth B-spline, after setting Deviation to a small enough value.
Bingo! Thanks vm4dim,
Thank you all for your inputs!
That actually works very well. I had tried that before but had forgotten that this format is a vector format (geometric construct) and therefore scalable. I loaded it in GIMP which allows to set the resolution upon import. I increased the resolution to 500PPI (0.002") and I had a high resolution bitmap which is exportable to PDF and can be sent to a printer! Once printed, the scale can be verified by measuring the distance between reference points in the drawing and the image scaling readjusted (x and y directions) to compensate for printer distortions.
I'll have to try this too. You import where and adjust the Deviation where?
Which comments? Anyway, I implemented a Python wrapper for the "hidden-line-removal" algorithm of the CAD kernel that allows me to use it directly without fearing that there is any pre- or post-processing step that reduces the quality.From the comments in the source code, this was a choice of the programmer that concluded that since the display could not resolve higher resolution that this was not necessary.... wrong!
Here is the script that does the same as the TechDraw function:
shape = App.ActiveDocument.Pad.Shape
hlr = Part.HLRBRep.Algo()
hlr.add(shape)
hlr.update()
hlr.hide()
res = Part.HLRBRep.HLRToShape(hlr)
v = res.vCompound()
Part.show(v)
v.Edge1.Curve.Degree # this gives 1
wmayer wrote: ↑Tue Dec 21, 2021 10:00 am Here is the script that does the same as the TechDraw function:Code: Select all
hlr = Part.HLRBRep.Algo() res = Part.HLRBRep.HLRToShape(hlr)
Sorry for the intrusion, but what version of FreeCAD include "Part.HLBRep..."
I have just downloaded latest 0.20 AppImage, and I don't find it. (At least searching in the Python Console autocompletion).
OS: Artix Linux (openbox)
Version: 0.20.26683 (Git) AppImage
Branch: (HEAD detached at 0388fbc)
Hash: 0388fbc98d49d874fb341b9037a743bc691d501f
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Maybe I was doing something wrong.
Regards
Carlo D.
- Various other stuffs.
It's always the latest
Or to be more precise you need:
Version: 0.20.26711
Hash: git commit 73a986714c106a
OK I have to wait untill the weekly build is updated.wmayer wrote: ↑Tue Dec 21, 2021 1:09 pm It's always the latest
Version: 0.20.26711
Maybe after Christmas
Merry Christmas to you and thanks for your work.
Best Regards
Carlo D.
