Extension tools: Use of sMenuText and setText? Translation context?
Roy_043
Post by Roy_043 »
In CommandExtensionPack.cpp I notice that there are two ways that menu texts are set: with sMenuText and setText. Why is that? And shouldn't the texts be identical for a given command?
https://github.com/FreeCAD/FreeCAD/blob ... k.cpp#L245
    sMenuText       = QT_TR_NOOP("Draw circle center lines");
https://github.com/FreeCAD/FreeCAD/blob ... k.cpp#L346
    arc1->setText(QApplication::translate("TechDraw_Extension", "Add Centerlines to Circles"));
There is also perhaps an issue with the translation context:
The first string (automatically I think) uses the command name "CmdTechDrawExtensionCircleCenterLines" as the context, the second "TechDraw_Extension".
wandererfan
Re: Extension tools: Use of sMenuText and setText? Translation context?
Post by wandererfan »
Roy_043 wrote: Tue Jan 18, 2022 7:07 pm In CommandExtensionPack.cpp I notice that there are two ways that menu texts are set: with sMenuText and setText. Why is that? And shouldn't the texts be identical for a given command?
sMenuText is for the TechDraw menu in the main tool bar (File, Edit, ...). setText is for the drop down buttons in the extension toolbar.
Yes, the text should be the same.
Roy_043
Post by Roy_043 »
Thanks. I'll try to create a PR to improve things.
AFAICT you should use the command name ("CmdTechDrawExtensionCircleCenterLines" in the example) as the context for setText and also for setToolTip.
But here two different contexts are used for these functions:
https://github.com/FreeCAD/FreeCAD/blob ... #L647-L668
Is there is special reason for this?
wandererfan
Roy_043 wrote: Tue Jan 18, 2022 9:22 pm But here two different contexts are used for these functions:
I can't think of one. Probably just blind cut, paste and edit.
Roy_043
Post by Roy_043 »
Two other contexts that are perhaps questionable: "Command" and "QObject" are not very specific:
Gui::Command::openCommand(QT_TRANSLATE_NOOP("Command", "Cosmetic Arc"));
QObject::tr("TechDraw Hole Circle")
Founder
Post by wmayer »
This must not be changed because the context "Command" is used by the undo/redo dialogs. In order to have the transaction text translated a specific and fix context string is mandatory and the choice was "Command" as it's not too long.
This could be changed.
Roy_043
Post by Roy_043 »
wmayer wrote: Wed Jan 26, 2022 10:09 am used by the undo/redo dialogs
This is then not correct I assume?:
https://wiki.freecadweb.org/Translating_an_external_workbench wrote:Do not translate the text of document transactions made with Document.openTransaction()
Founder
Post by wmayer »
No. It's perfectly allowed to translate transaction texts, too. However, it wasn't supported in the past.
openBrain
Post by openBrain »
Roy_043 wrote: Wed Jan 26, 2022 9:57 am Two other contexts that are perhaps questionable: "Command" and "QObject" are not very specific:
IIRC, when using QObject::tr(), the context is automatically added as being the class name. ;)
Roy_043
Post by Roy_043 »
