[Feature Request] Surface finish symbols [SOLVED]
bensay
Re: [Feature Request] Surface finish symbols [SOLVED]
Post by bensay »
edi wrote: Sat Jul 30, 2022 3:35 pm If somebody wants to receive the source code, please tell me.
I won't promise anything, but i would gladly take a look at it. Also, it shouldn't be that you got Discord?
user1234
Post by user1234 »
FBXL5 wrote: Sun Jul 31, 2022 10:49 pm Maybe the field could be split in two:
- One to choose Ra. Rz, or none to edit manually.
- and following a box with given values and the choice to type a value manually.
I would let the field empty for edit, because there is no need to make it more complex.
wandererfan wrote: Fri Jul 29, 2022 2:31 pm All yours. Let me know if you get stuck.
Time is my enemy. They saw i had a little time to do my own things, so they decided to bury more work on me.
Greetings
user1234
PitiBon
Post by PitiBon »
I need to include surface roughness on drawings and tried version 1 and 3 of the macro in this thread and they don't work
I'm on Mac OS Monterey 12.5
and have Freecad 0.20.1
any pointers?
NewJoker
Post by NewJoker »
It’s a built-in tool in 0.21 dev version: TechDraw SurfaceFinishSymbol
Cuq
Post by Cuq »
NewJoker wrote: Fri Jan 20, 2023 12:28 am It’s a built-in tool in 0.21 dev version: TechDraw SurfaceFinishSymbol
Unfortunately the symbols are already obsolete the notation is no longer in accordance with ISO 25178-1 & ISO 21920-1
Geometrical product specifications (GPS) - Surface texture : profile - Part 1 : indication of surface texture Full sample notation
Geometrical product specifications (GPS) - Surface texture : Area- Part 1 : indication of surface texture Full sample notation
These notation are of course a full capability description sample notation but it would be nice to have the new standard Symbol for Area and Profile Surface Finish
Graphical Symbols Profile.PNG (43.01 KiB) Viewed 1000 times
Graphical Symbols Area.PNG (43.59 KiB) Viewed 1000 times
edi
Post by edi »
Do you just want the tool to be expanded by additional symbols, or more ?
NewJoker
Post by NewJoker »
Old symbols are still in use, likely more commonly than new ones. I definitely wouldn’t remove them, maybe add new versions if really needed.
edi
Post by edi »
Find attached version 5 of SurfaceSymbols.Macro extended by the desired icons.
SurfaceSymbols05.FCMacro
(11.41 KiB) Downloaded 34 times
TaskSurfaceFinishSymbols05.ui
(7.78 KiB) Downloaded 37 times
Installation:
Copy the two files SurfaceSymbols05.Macro and TaskSurfaceFinishSymbols05.ui into your macro directory. Usage is equal as in the older versions.
Please post ideas for improvements or issues.
NewJoker
Post by NewJoker »
@edi I tested it, works great. Could you make a PR to add those new symbols to the built-in SurfaceFinishSymbol tool ?
Cuq
Post by Cuq »
edi wrote: Sat Apr 15, 2023 2:49 pm Find attached version 5 of SurfaceSymbols.Macro extended by the desired icons.
SurfaceSymbols05.FCMacroTaskSurfaceFinishSymbols05.ui
You will Find herewith a version 06 ... Ra is written with upper case R and lower case a.
From my point of view it should be more a free text than only the choice on the Ra ... In the ISO 21920-2 standard there are more than a hundred parameters. Limiting to one out of 100 is not to promote the use of this marco.
SurfaceSymbols06.FCMacro
(11.41 KiB) Downloaded 28 times
