TechDraw_ProjectionGroup: Function of the Apply button?
Roy_043
Post by Roy_043 »
What is the function of the Apply button in the task panel of the TechDraw_ProjectionGroup command. AFAICT the inputs are applied immediately.
Re: TechDraw_ProjectionGroup: Function of the Apply button?
Roy_043 wrote: Fri Apr 15, 2022 7:35 am What is the function of the Apply button in the task panel of the TechDraw_ProjectionGroup command. AFAICT the inputs are applied immediately.
I would have expected that Apply does a commit, so that a later cancel will rollback to the Aply-state. Alas, Cancel removes everything. I would consider that as a bug - which is easily fixed by removing the button.
wandererfan
Post by wandererfan »
IIRC, it used to be possible to set the values in the dialog without having the page updated until Apply was pressed. If the dialog now applies changes immediately, then the Apply button has no purpose.
fabianinostroza
Post by fabianinostroza »
wandererfan wrote: Fri Apr 15, 2022 4:56 pm
I find annoying that the changes are applied immediately, sometimes I have to wait a lot of time to change multiple options because with every change it is recomputing the views and sometimes the models are big.
wandererfan
fabianinostroza wrote: Tue May 17, 2022 3:49 pm I find annoying that the changes are applied immediately, sometimes I have to wait a lot of time to change multiple options because with every change it is recomputing the views and sometimes the models are big.
Yes, I find it annoying also. The fix will be implemented early in the v0.21 cycle.
