Missing paths in AppImage (Hatch Pattern File, Line Group File, Welding Directory and PAT File)
M4x
Post by M4x »
Hey,
I've a problem regarding the pathes to the Hatch Pattern File, Line Group File, Welding Directory and PAT File. I know this error message from using FreeCAD-AppImages in general:
Line Group File: /tmp/.mount_FreeCAGpp7sd/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
I think this used to happen when the AppImage used another temporary directory and the known path didn't update correctly. My solution was to delete the pathes and restart FreeCAD. Afterwards I've used to found the correct pathes and everything was okay.
Now I've another problem: The pathes are missing completely:
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.28929 (Git) AppImage
Branch: (HEAD detached at 6f24fd3)
Hash: 6f24fd3053a89a5fb12ab765f9df93ec04deeac1
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * LCInterlocking
  * kicadStepUpMod 10.12.4
  * Lithophane
  * lattice2 1.0.0
  * Defeaturing
  * Manipulator
  * fasteners 0.3.41
  * sheetmetal 0.2.49
  * Assembly4
  * Curves
  * POV-Ray-Rendering
  * 3DfindIT 1.2.0
Am I the only one? What should I do?
Thanks!
M4x
Re: Missing pathes in AppImage (Hatch Pattern File, Line Group File, Welding Directory and PAT File)
Post by M4x »
I've made some further tests. I'm not sure if it's something TechDraw-specific. I tend to say no, it's not.
Error message when launching FreeCAD from the terminal (my usual user):
Line Group File: /tmp/.mount_FreeCAlFyO9h/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
This is how the permissions for the temporary directory look like:
drwxr-xr-x  3 root root       0 Mai 26 14:27 .mount_FreeCAlFyO9h
I'm using FreeCAD as another user (non root). Launching FreeCAD as root works fine.
running AppImage as root
And this is the temp directory from the 0.19 AppImage (non root user):
drwxr-xr-x  3 root root       0 Dez 15 00:39 .mount_FreeCA5QEksA
After I was able to run 0.20 as root without an error message, I thought I have a permission error. But I don't have a problem using 0.19 as a non root user. The permissions for the temporary directories are identical for 0.19 and 0.20.
kaktus
Post by kaktus »
Hi.
I am using AppImage, after running this workbench at my place everything is ok.
however, this error message is not unfamiliar to me.
18:06:54  flag
18:22:29  LineGroup error: no group found in file /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/
18:26:39  LineGroup: the LineGroup file has only 0 entries but entry number -1 is set
18:26:39  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.20.28945 (Git) AppImage
Branch: (HEAD detached at 0fb7cd9)
Hash: 0fb7cd9758d850f536d571cc094c9833fee18fff
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Polish/Poland (pl_PL)
Installed mods:
wandererfan
Post by wandererfan »
kaktus wrote: Mon May 30, 2022 4:31 pm however, this error message is not unfamiliar to me.
I've never seen this message except in testing. I can make the first message appear by removing all the group entries from the LineGroup.csv file. Have not been able to generate the second message yet.
Can you post your LineGroup.csv file? What is your setting for the group name (Preferencja>Adnotacja>Szerokosc kinii w grupie)?
kaktus
Post by kaktus »
All settings are default.
I did not prepare additional files. :roll: This model has been modified many times, is it possible for something to break by itself :?:
I will send you a test file.
This way you will be able to check everything yourself.
If there's anything else I can help with I'm around. :idea:
szablon_przyciskow.FCStd
(36.27 KiB) Downloaded 25 times
kaktus
Post by kaktus »
okay
I found the file you asked about.
LineGroup.csv
(1.05 KiB) Downloaded 27 times
kaktus
Post by kaktus »
Default settings.
The option you are asking about does not have a value in the checkbox.
Edit:
My clicking on this checkbox does not have any effect. :roll:
The options are not available.
M4x
Post by M4x »
It's working with default config files (= deleted user and system.cfg) :oops: Because I've seen this "update path error" several times using AppImages, I've thought that it would be something else. Sorry, I should've known better to delete my config first.
Now I'll have a look at my settings to "recreate" them. By the way: Is there a better way than going through the GUI?
I'm not going to mark this thread solved yet, because we're currently discussing the issue of user @kaktus
kaktus
Post by kaktus »
@wandererfan
Does your silence on the subject mean that my problem is only localized to me :?:
Warm greetings.
edit:
I did not make any changes. Today after opening the test file I get different messages.
07:46:20  flag
07:47:41  Line Group File: /tmp/.mount_FreeCAOGxou4/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
07:47:41  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
07:47:41  LineGroup::invalid entry in /tmp/.mount_FreeCAOGxou4/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
kaktus
Post by kaktus »
:roll:
All in all, I removed the TechDraw folder from the location:
~/.FreeCAD/usr/share/Mod/
I forgot about it. I've been doing too many things at once lately.
