[SOLVED] Performance hit -> DetailView in 0.20.28929 vs. 19.24366
M4x
Post by M4x »
Hey,
I've recognized a massive performance hit while changing DetailViews (TechDraw_DetailView) in 0.20 compared to 0.19. In 0.20, it takes 8 to 12 seconds to increment the radius by 1 mm and "free up" the mouse again (= changes the input field if I click in it). I can see one CPU core going up to 100% and the fan starts spinning. On 0.19, such adjustments happen instantly. I've attached my example file.
I don't know if it's related, in 0.20 I'm having problems regarding the pathes for the Hatch Pattern File, Line Group File, Welding Directory and PAT File: https://forum.freecadweb.org/viewtopic.php?f=35&t=68996
Snip macro screenshot-964a8d.png (44.92 KiB) Viewed 711 times
I've used this versions:
OS: Ubuntu 20.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Version: 0.20.28929 (Git) AppImage
Branch: (HEAD detached at 6f24fd3)
Hash: 6f24fd3053a89a5fb12ab765f9df93ec04deeac1
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * LCInterlocking
  * kicadStepUpMod 10.12.4
  * Lithophane
  * lattice2 1.0.0
  * Defeaturing
  * Manipulator
  * fasteners 0.3.41
  * sheetmetal 0.2.49
  * Assembly4
  * Curves
  * POV-Ray-Rendering
  * 3DfindIT 1.2.0
Thanks!
TD_DetailView_1.FCStd
(49.85 KiB) Downloaded 11 times
wandererfan
Re: Performance hit -> DetailView in 0.20.28929 vs. 19.24366
Post by wandererfan »
M4x wrote: Sat May 28, 2022 1:14 pm I've recognized a massive performance hit while changing DetailViews (TechDraw_DetailView) in 0.20 compared to 0.19.
First thing to look at is "Debug Detail" on the Advanced tab in Preferences. It should be unchecked. If it is checked, there will be a bunch of disk I/O that will slow things down.
Here, my v0.20 recomputes are ~4 seconds, not 8-12 seconds. V0.19 is faster, but v0.20 is doing more work to eliminate visual artifacts in the detail view.
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.20.28949 +1 (Git)
Build type: debug
Branch: fixSpuriousRecompute
Hash: fedbaa2589c8ff8a828d1a338896aed5deee73c9
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
Installed mods:
  * A2plus 0.4.54b
  * Curves 0.3.0
  * fasteners 0.3.40
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
M4x
Post by M4x »
Thanks for your reply! "Debug Detail" is unchecked. However, today I'm not able to reproduce the described behavior. Therefore I'll mark this thread as solved.
Thanks!
