Template genreator
tobiasfalk
Template genreator
Post by tobiasfalk »
I created a small Python script witch creates me a sheet template for both TechDraw and KiCAD and I wanted to ask your opinion and maybe also your ideas for improvements.
https://github.com/tobiasfalk/KiCAD-Fre ... -Generator
ISO_216_A4L_ISO_5457-1999_ISO_7200-2004.freecad.svg
(10.71 KiB) Downloaded 44 times
ISO_216_A4L_ISO_5457-1999_ISO_7200-2004.svg
(10.59 KiB) Downloaded 30 times
ISO_216_A3_ISO_5457-1999_ISO_7200-2004.freecad.svg
(14.29 KiB) Downloaded 31 times
ISO_216_A3_ISO_5457-1999_ISO_7200-2004.svg
(14.16 KiB) Downloaded 36 times
FBXL5
Re: Template genreator
Post by FBXL5 »
I have no clue how this GitHub stuff works and so don't know how to test the script(s). :?
But what I know is that A4 landscape format is more or less useless. It is not recommended since ages. I was told so in the mid 1980s and it wasn't a new insight even back then. :roll:
The structure of the svg file is quite ok when indentation is added.
The stroke width of 0.7 and 0.35 is a bit too much for A3 and A4.
Roy_043
Post by Roy_043 »
tobiasfalk
Hi, I reprogramed the whole think in C++ with Qt and alsow added some more fetures and would like to ask for the opinion from the FreeCAD Comunety. In the release there is alsow a precompield version for Windows and I hope that the Readme explains everything that is needed.
Greeteings
Tobias
Laurie Hartley
Post by Laurie Hartley »
tobiasfalk wrote: Fri Oct 07, 2022 7:20 am Hi, I reprogramed the whole think in C++ with Qt and alsow added some more fetures and would like to ask for the opinion from the FreeCAD Comunety. In the release there is alsow a precompield version for Windows and I hope that the Readme explains everything that is needed.
Greeteings
Tobias
I had a quick browse through the files on GitHub Tobias. You have put a lot of work into this. I like what I have seen. I am a bit strapped for time at the moment but I will try them out for sure in the near future.
