(WORKAROUND) Speed ​​by techdraw
uwestoehr
Re: Speed ​​by techdraw
Post by uwestoehr »
wandererfan wrote: Sun Jul 03, 2022 2:07 pm We already know why this is slow. The OCC HLR algo does thousands of edge and face intersection calculations sequentially.
OK, but is there an option where the user can turn off the HLR? I mean there is often no need to remove the hidden lines.
Besides this, the second issue is the unresponsiveness. As I wrote , this is on Windows a big issue since the OS will sooner or later try to kill FC because it detects it as unresponsiveness. The the users this action appears as if FC crashed.
wandererfan
Post by wandererfan »
uwestoehr wrote: Sun Jul 03, 2022 2:36 pm OK, but is there an option where the user can turn off the HLR? I mean there is often no need to remove the hidden lines.
Not really, no. Even if you only want the visible lines, you still need to figure out what faces occlude which lines, where the occlusion takes place, and how much of the line is still visible. HLR does all this, plus the projection onto the page.
The only speed-up option provided by OCC is the coarse (polygon) method which turns all the lines into segments and is useless for dimensioning.
uwestoehr
Post by uwestoehr »
wandererfan wrote: Sun Jul 03, 2022 3:24 pm Not really, no.
So we cannot do anything here regarding the speed.
That is sad. However, then we should mention this in the Wiki that people are aware of this. Since you have the background knowledge, could you maybe add a paragraph to https://wiki.freecadweb.org/TechDraw_Wo ... imitations ?
thomas-neemann
Re: (WORKAROUND) Speed ​​by techdraw
Post by thomas-neemann »
thanks to everyone for the effort. as computers are getting faster and faster, the problem should also become smaller and smaller
Founder
Post by wmayer »
This depends on how the HLR algorithm is implemented. In case it internally uses static or global variables then there is no way to run the algorithms in parallel. But if there is no such limitation we can run the actual algorithm in a thread. The code to do so would be of this form:
QFuture<TopoDS_Shape> future = QtConcurrent::mapped(myShapes, [](const TopoDS_Shape& shape) {
        // put here the call of the HLR algorithm
QFutureWatcher<TopoDS_Shape> watcher;
watcher.setFuture(future);
watcher.waitForFinished();
for (QFuture<TopoDS_Shape>::const_iterator it = future.begin(); it != future.end(); ++it) {
    // use the results
If needed the QFutureWatcher can be combined with an QEventLoop to keep the application responsive.
wandererfan
wmayer wrote: Sun Jul 03, 2022 4:52 pm If needed the QFutureWatcher can be combined with an QEventLoop to keep the application responsive.
Thanks for the clues.
I made a quick proof of concept using QtConcurrent::run to execute a modified GeometryObject::projectShape in a separate thread and it seems to work fine. Of course, this is a blocking situation so it didn't actually do anything to solve the actual problem.
I'll have to figure out how to run projectShape asynchronously so the main thread can continue on.
Still not sure how to get progress reporting. We can't partition the workload by shape (as in your sample code) since hlr needs the whole input shape at the same time to calculate the occlusions. We might be able to separate disjoint shapes, but that isn't the standard use case.
Founder
Post by wmayer »
You can try it this way:
QEventLoop loop;
QObject::connect(&watcher, &QFutureWatcher<TopoDS_Shape>::finished, &loop, &QEventLoop::quit);
loop.exec();
    // use the results
If you have a single shape only then there is no way to show a progress indicator. There we would have to wait for OCC to implement it. However, if you have several shapes to be processed you can use the class Base::FutureWatcherProgress
Base::FutureWatcherProgress progress("Hidden line removal...", numberOfShapes);
QObject::connect(&watcher, &QFutureWatcher<TopoDS_Shape>::progressValueChanged,
                             &progress, &Base::FutureWatcherProgress::progressValueChanged);
QEventLoop loop;
loop.exec();
wandererfan
a quick update for anybody following this saga...
I have an async prototype working that sends hlr off to a separate thread, returns control to the main thread so the gui is freed up, then updates the view when the separate thread completes.
next steps:
- move the face finding logic (the second biggest time consumer) off to a separate thread,
- investigate progress reporting,
- refactor the messy prototype code into something maintainable.
wandererfan wrote: Fri Jul 08, 2022 1:07 pm I have an async prototype working that sends hlr off to a separate thread,
That sounds promising! Thanks for the work!
user1234
Post by user1234 »
wandererfan wrote: Fri Jul 08, 2022 1:07 pm I have an async prototype working that sends hlr off to a separate thread, returns control to the main thread so the gui is freed up, then updates the view when the separate thread completes.
With that your are better then the most commercial CADs. Incredible!
Greetings
user1234
