[SOLVED] LineGroup::invalid entry in LineGroup.csv
kaktus
Post by kaktus »
For some time now this message has accompanied me every time I start FreeCAD after loading a drawing page.
it looks as follows:
wall of red text ... :?
08:23:29  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:23:29  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:23:55  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:23:55  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:23:59  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:23:59  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:24:03  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:24:03  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:24:06  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:24:06  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:24:11  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:24:11  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:24:16  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:24:16  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:25:26  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:25:26  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:25:41  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:25:41  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:26:02  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:26:02  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:26:21  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:26:21  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:26:33  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:26:33  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:27:13  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:27:13  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
08:27:33  LineGroup: the LineGroup file has only 7 entries but entry number -1 is set
08:27:33  LineGroup::invalid entry in /home/kaktus/.FreeCAD/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv
My basic set-up for the TechDraw workbench:
My LineGroup file:
19:24 kaktusek@donica:~/.FreeCAD/usr/share/Mod/TechDraw/LineGroup$ ls -l
razem 12
-rw-r--r-- 1 kaktus kaktus 1070 07-03 18:24 LineGroup.csv
LineGroup.csv
(1.04 KiB) Downloaded 25 times
Errors occur practically when loading any project file from several versions of FC releases. :x
Do you have any ideas on how to get rid of them :?:
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.21.29365 (Git) AppImage
Hash: 59b945dcc329303ad781075ecf30544aab909415
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Polish/Poland (pl_PL)
Installed mods:
zatyczka.FCStd
(105.49 KiB) Downloaded 24 times
Shalmeneser
Re: LineGroup::invalid entry in LineGroup.csv
Post by Shalmeneser »
Some messages opening your file :
Line Group File: C:/***/FreeCAD_weekly-builds-28929-Win-Conda-x86_64/data/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
20:43:27  INFO - ViewProviderPage::getMDIViewPage has no m_mdiView!
20:43:29  TIMING - ProjItem GO spent: 60.989 millisecs in HLRBRep_Algo & co
20:43:29  TIMING - ProjItem GO spent: 1.762 millisecs in hlrToShape and BuildCurves
20:43:29  TechDraw::GeometryObject::addGeomFromCompound edgeCompound is NULL
20:43:29  INFO - ViewProviderPage::getMDIViewPage has no m_mdiView!
20:43:29  TIMING - ProjItem001 GO spent: 34.864 millisecs in HLRBRep_Algo & co
20:43:29  TIMING - ProjItem001 GO spent: 1.901 millisecs in hlrToShape and BuildCurves
20:43:29  TIMING - ProjItem002 GO spent: 35.294 millisecs in HLRBRep_Algo & co
20:43:29  TIMING - ProjItem002 GO spent: 1.913 millisecs in hlrToShape and BuildCurves
20:43:29  TIMING - ProjItem003 GO spent: 34.953 millisecs in HLRBRep_Algo & co
20:43:29  TIMING - ProjItem003 GO spent: 1.889 millisecs in hlrToShape and BuildCurves
20:43:29  INFO - QGIVD::draw - no parent to update
kaktus
Post by kaktus »
With you there is also a problem with the LineGroup.csv file
did you check if it exists in the specified location?
What do you have entered in TechDraw preferences?
wandererfan
Post by wandererfan »
kaktus wrote: Tue Jul 05, 2022 8:19 pm
What is your setting for LineGroup on the Annotations tab in Preferences?
Shalmeneser
:arrow:
zatyczka_SHALM.FCStd
(94.13 KiB) Downloaded 32 times
Capture d’écran 2022-07-06 093012.jpg (27.4 KiB) Viewed 1152 times
kaktus
Post by kaktus »
wandererfan wrote: Wed Jul 06, 2022 1:01 am ...
This is probably where the problem was. In my case nothing was entered in this place.
Now I am not able to check what result will come from defining this option because I went on vacation and do not have access to my projects.
But I expect positive results.
After completing the indicated option, the message about the LineGroup file when I created a new project stopped bothering me. :D
By the way, the name of the option "Line Width Group" is uncommunicative to me. :roll:
To be honest, I was wondering where the line widths on the drawing page are defined (and if they are there at all).
Thanks to your information I found out that they are and how to change them according to my own criteria.
Perhaps the description in the option hint could be better. Until now I didn't know what the line group refers to.
I thought that the user can define his line groups and for individual needs define their visual characteristics.
And in fact it is a very helpful option that defines the basic dependencies of line features depending on their type.
As a translator, I will be able to improve the displayed content for the option in Polish. ;)
Shalmeneser thank you for taking on the topic and trying to solve my problem.
I will ask for two words of commentary on your picture because I don't know what you mean.
Shalmeneser
My file is not an answer, just an other way of doing your object.
kaktus
Post by kaktus »
ah -ok
thanks to :D
I'll take a look at it.
edit:
well but your message has no attachment
you only posted a snippet with a screenshot :roll:
Shalmeneser
The file is above the image. :roll:
kaktus
Post by kaktus »
I didn't notice before...
:lol:
