IMO yes, at least for popular features like this or paddle's sketcher stuff or specially TN, of course not as many as with the dev releases but even one is better than no testing.
TechDraw Multithread Testing
- adrianinsaval
Re: Multithread Testing
@Kunda1, @adrianinsaval: yes, convinced, thanks.
btw: this feature is merged from @wandererfan, thank you very much!
@Kunda1: two things, since you are very good in managing or maybe even you created this or at least you know, who is managing this:
- in the PRs are a link to the 0.20 changelog, i think this should be updated to a new thread to 0.21. I did not find one (too common search terms, maybe there is no one). This feature should be added, since it is a gamechanger for people which make TechDraw drawings.
- the wiki https://wiki.freecadweb.org/Release_notes_0.21 is empty. I do not know who created this, this feature should be added too.
@wandererfan: i found a minor issue: which was not before, when trying to close before the recalcultaing is finnished, i get a message
terminal:
log:
Could it be, that in the line
https://github.com/FreeCAD/FreeCAD/blob ... t.cpp#L164
%S must be replaced with %s?
Greetings
user1234
terminal:
������������������嘓������嘓������������1 is waiting for face finding to finish
Msg: \FD\AA\9B\B7\89\90\FD\AD\99\97\91\89\FC\A5\85\BA\B0\80嘓\FC\AB\B8\83\BB\80嘓\FC\BD\8E\A7\A0\99\FC\91\95\90\B3\A01 is waiting for face finding to finish
Greetings
user1234
- wandererfan
At times like these, I regret only being able to swear in two languages.
The check for running threads at close time was added to hlrThreadrc2 to prevent a segfault. I'll fix the typo directly. Thanks for reporting.
C and C++? (this is just a joke).
I can make it and the good thing is, while searching this issue, i learned something.wandererfan wrote: ↑Thu Aug 18, 2022 3:03 pm The check for running threads at close time was added to hlrThreadrc2 to prevent a segfault. I'll fix the typo directly.
Greetings
user1234
Besides that, if someone does not work, someone can not make errors. Also we say here, when some does planing, there are chips. That is a fact that may new users (here, not in gerneral) forget.
Greetings
user1234
Greetings
user1234
This is probably due to the plan that the next version will be v1.0 Release_notes_1.0. Thanks for the heads up.
CC @uwestoehr, should we update the PR template to link to 1.0 Release notes?
- adrianinsaval
- wandererfan
Should be fixed by git commit d6806167e1.user1234 wrote: ↑Thu Aug 18, 2022 2:55 pm i found a minor issue: which was not before, when trying to close before the recalcultaing is finnished, i get a message
terminal:Code: Select all
Already seen, compiled and tested, yes it works now. Thanks!
Greetings
user1234
- wandererfan
