TechDraw Multithread Testing
Tandini
Re: Multithread Testing
Post by Tandini »
Is it possible to test that on Windows?
wandererfan
Post by wandererfan »
user1234 wrote: Sun Jul 31, 2022 4:12 pm Log: TIMING - ProjItem001 GO spent: 294.545 millisecs in HLRBRep_PolyAlgo & co
I have to make some changes to handle the polygon approximation version of the HLR algos. That should fix this.
wandererfan
babaroga wrote: Sat Jul 30, 2022 9:14 pm In a matter of fact, there is one issue. When creating 3d view "Scale type" is set to Automatic and scale is set to 1.
I would stay away from Automatic, while I figure out how to fix this.
<techno-babble>The Scale property is getting updated and triggering AutoDistribute in the main thread, while the geometry is being calculated off in another thread using the old scale. </techno-babble>
wandererfan
Tandini wrote: Mon Aug 01, 2022 1:50 pm Is it possible to test that on Windows?
I don't think we have a facility for testing branches in Windows. You'd have to compile the branch yourself.
@Kunda1 is there an equivalent to branch based snaps in the Windows world?
I'd like to see this tested in Windows, as I don't have a Windows environment at the moment.
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Post by babaroga »
Ok. I figured that by myself.
My father used to say:
More automatic, more problematic.. :-)
wandererfan
babaroga wrote: Mon Aug 01, 2022 3:19 pm My father used to say:
He was obviously a smart man!
wandererfan
New version again. Problem with v019 file (Async motor) and polygon algo fixed. Problem with ScaleType Automatic also fixed I think. Don't know about the piece of the bed sticking out of the page. @balrobs any chance of a test file?
babaroga
Post by babaroga »
With new fixes, everything now seems to be OK. Automatic scaling is working, and there is no hidden underlying geometries.
I cannot measure, but my subjective feeling is that everything works ever faster than before. Anyway fans on my laptop does not spin like it is going to fly away.
Today I am busy with some paperwork, but tomorrow will test it in working environment. I will report if I spot anything.
wandererfan
A new snap is available for those that don't want to compile their own.
$ sudo snap install --channel=edge/pr-44 freecad
  # If you already have the freecad snap installed
  $ sudo snap refresh --channel=edge/pr-44 freecad
  # Experimental: Parallel install (see https://snapcraft.io/docs/parallel-installs)
  $ sudo snap set system experimental.parallel-instances=true
  $ sudo snap install --channel=edge/pr-44 freecad_pr44
  $ freecad_pr44 # Run it
Would like to see this tested on Windows before it goes to master. Any volunteers?
user1234
Post by user1234 »
wandererfan wrote: Tue Aug 02, 2022 10:52 pm New version again. Problem with v019 file (Async motor) and polygon algo fixed.
Yes, works thanks!
I did a little stress test. When change often really fast scale, direction, generally views or anything else with many views like in the projection group task, then FreeCAD can (must not) crash. Normally that is not a problem, if that happens, then someone demand this.
Err: Program received signal SIGSEGV, Segmentation fault.
Err: #0  /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7f1720eeed60]
Err: #1  0x7f15bb0a0553 in TechDraw::GeometryObject::addFaceGeom(std::shared_ptr<TechDraw::Face>) from /home/user/Programs/FreeCADhlrThreadrc1/build/Mod/TechDraw/TechDraw.so+0x3
Err: #2  0x7f15bb0308dc in TechDraw::DrawViewPart::extractFaces() from /home/user/Programs/FreeCADhlrThreadrc1/build/Mod/TechDraw/TechDraw.so+0xaac
Err: #3  0x7f15bb0313f5 in non-virtual thunk to QtConcurrent::RunFunctionTask<void>::run() from /home/user/Programs/FreeCADhlrThreadrc1/build/Mod/TechDraw/TechDraw.so+0x25
Err: #4  /lib/x86_64-linux-gnu/libQt5Core.so.5(+0xcfed2) [0x7f172132eed2]
Err: #5  /lib/x86_64-linux-gnu/libQt5Core.so.5(+0xccbe1) [0x7f172132bbe1]
Err: #6  /lib/x86_64-linux-gnu/libpthread.so.0(+0x8ea7) [0x7f1720e99ea7]
Err: #7  /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f1720fb0def]
Err: #1  [0x55643d1264f0]
Greetings
user1234
