[Bug] Updating FreeCAD: linegroup file not found
I uninstalled FreeCAD 0.19 and kept user settings. Installed FreeCAD 0.20. As using TechDraw, the linegroup file was not found as it was still referring to the folder where 0.19 was installed. I would consider this a bug. Could anyone confirm if they experienced the issue after updating FreeCAD too?
- wandererfan
Re: [Bug] Updating FreeCAD: linegroup file not found
Your line group preference is pointing to a folder that doesn't exist any more? It will use a default based on ResourceDir if the preference isn't found.
Hi.
This topic contains my adventures
maybe something will be helpful to you.
https://forum.freecadweb.org/viewtopic. ... 35&t=70035
