- QQ图片20220817153904.png (93.57 KiB) Viewed 650 times
How to get a SectionView between 3000 and 6000 ?
Re: How to get a SectionView between 3000 and 6000 ?
Hi and welcome to the forum!
Depending on the orientation you change the X, Y, or Z value of the Section Plane Location.
Thank you. I think I didn't express it well. In fact, looking down from the height of 6000, as of 3000, the current setting will display the section under 3000,
- Shalmeneser
You can have views of different objects or different steps of the same object.
You can add cutting steps of your object and add this view.
- TehcDraw_2xCut_SHALM.FCStd
- (33.5 KiB) Downloaded 14 times
- wandererfan
There is no function to take a draw a slice of an object. You'd have to make the slice in the 3d model first.
The other option is to hide the lines you don't like by setting them invisible with TechDraw_DecorateLine.
Hi zyh, greetings to the Community!
The "translation", in a trivial example, of what @wandererfan recommends as the first option.
- Section_of_a_zone.FCStd
- (54.3 KiB) Downloaded 9 times
- Section_of_a_zone.png (182.81 KiB) Viewed 476 times
