how to change the dimension Value?
Jacq
Post by Jacq »
How to change the dimension value?
like that the Value of Length Dimension is 10, I'd want to change it to 20 or 'X', is it possible ?
thanks.
Re: how to change the dimension Value?
Hi and welcome to the forum!
You can override it by setting Arbitrary=false and then entering the new value in then FormatSpec property. However, this doesn't change your model. So you should rather change the size of your model and the dimension will follow.
Jacq
Post by Jacq »
thank you.
it works.
