On the problem of stuck top view in TechDraw of ladder loading
zyh
Post by zyh »
Ladder.py
(515 Bytes) Downloaded 14 times
Re: On the problem of stuck top view in TechDraw of ladder loading
Your information is a bit thin. First you should reproduce this in current 0.21 and add the FreeCAD infos.
Then you should give a detailed description how to reproduce.
user1234
Post by user1234 »
It works, but it takes a while (2min). Reason: the ladder spokes are a little bit slanted. The OCCT kernel does not like slightly slanted views. I am not a macro expert, but i am pretty sure, that you use the base vector wrong.
Greetings
user1234
domad
Post by domad »
Greetings to the Community!
No problem found, except that of excessive time in loading and creating views in TechDraw (the reason may be the one mentioned by @ user1234, but what if the scale was really like this?)
Here are the results of my experimentation, specifying that the option "Detect faces" has been disabled in the TechDraw preferences, and a new scale identical to "Shape" has also been modeled to make comparisons:
- Top view creation time of "Shape" -> 5 ': 30 ";
- Top view creation time of "Body" -> 25 ";
- File loading time "TechDraw_ladder_loading_Shape_and_Body.FCStd" containing "Shape" and "Body" and the TechDraw page with the two Top views (Shape and Body) -> 18 ': 45 ";
- File loading time "TechDraw_ladder_loading_no_Shape.FCStd" containing only "Body" and the TechDraw page with only Top view (Body) -> 3 ': 25 ".
Attached are the files mentioned above.
Old computer:
- i7-1.6
- HD solid state
- 8 GB ram
- 1GB video card
OS: Linux Mint 20.3 (X-Cinnamon / cinnamon)
Version: 0.21.30089 (Git) AppImage
Hash: 335196a468fcf069f365dcbb24279a8295cc4683
Local: Local
(489.96 KiB) Downloaded 11 times
(360.28 KiB) Downloaded 10 times
View creation time.png (116.03 KiB) Viewed 453 times
