MultiThread Is In Master
wandererfan
Post by wandererfan »
I merged the hlrThreadrc2 branch to master this morning. This branch is based on hlrThreadrc1 with some clean ups.
EXPECTATION MANAGEMENT
The multithreading does not extend to the actual OCC hidden line algorithms or to the FC face detection algorithm. Load and recompute times will reflect the most complex View in the file. If your file contains 1 complex View, you will not notice an improvement, except that you will be able to carry on with other tasks while the view is recomputing. On the other hand, if your file contains a number of Views, you should see an improvement as the various views will be recomputed in parallel.
A big thank you to everybody, especially user1234, who helped with the testing and to werner for the hints on how to do separate threads.
user1234
Re: MultiThread Is In Master
Post by user1234 »
Yeah! Many thanks!
Greetings
user1234
Haavard
Post by Haavard »
Awesome ! :D
Post by Kunda1 »
Early testing should be available on Snap 'edge' channel.
-alex-
Post by -alex- »
Thank you for this great enhencement, it brings FC to a higher level, very useful.
user1234 wrote: Thu Aug 18, 2022 2:58 pm Yeah! Many thanks!
+1
bensay
Post by bensay »
Kunda1 wrote: Thu Aug 18, 2022 4:12 pm Early testing should be available on Snap 'edge' channel.
We really need some Windows pipelines too. First of all to make sure compiling also works in Windows. Second of all to allow user testing on Windows, where the majority of FreeCAD users probably belong
Post by Kunda1 »
bensay wrote: Fri Aug 19, 2022 9:53 pm We really need some Windows pipelines too.
@bensay indeed. No one has stepped up yet to provide one (besides using conda)
