[Solved] [Bug] [Windows] Techdraw error message with special characters in the username
Haavard
Post by Haavard »
I get the following message in the report view when inserting a view on a new techdraw page:
09:10:21  Cannot open LineGroup file: C:/Users/SpecialUsernameÆÅØ/AppData/Local/Programs/FreeCAD 0.20/data/Mod/TechDraw/LineGroup/LineGroup.csv
09:10:21  LineGroup::invalid entry in C:/Users/SpecialUsernameÆÅØ/AppData/Local/Programs/FreeCAD 0.20/data/Mod/TechDraw/LineGroup/LineGroup.csv
I would guess it is related to other special character issues:
https://forum.freecadweb.org/viewtopic.php?f=3&t=69825
https://forum.freecadweb.org/viewtopic.php?f=19&t=71219
OS: Windows 10 Version 2009
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Norwegian Bokmal/Norway (nb_NO)
wandererfan
Re: [Bug] [Windows] Techdraw error message with special characters in the username
Post by wandererfan »
Haavard wrote: Fri Aug 19, 2022 7:23 am I get the following message in the report view when inserting a view on a new techdraw page:
If you type "App.getResourceDir()" in the Python console, what do you get?
bensay
Post by bensay »
I am pretty sure it is this bug: https://forum.freecadweb.org/viewtopic.php?f=35&t=70876
The folder has gotten a new name after FreeCAD was updated to 20.1.
1) Did you start getting these errors right after having update to 20.1
2) Check if the folder C:/Users/SpecialUsernameÆÅØ/AppData/Local/Programs/FreeCAD 0.20/ exists - it is probably replaced by C:/Users/SpecialUsernameÆÅØ/AppData/Local/Programs/FreeCAD 0.20.1/ now
bensay
Post by bensay »
Oh, also, good to see other Danes in here
Founder
Post by wmayer »
git commit ff01905f0b should fix it.
All path names that are stored in a const char* or std::string are supposed to be UTF-8 encoded. For Linux or macOS there is no problem when using std::ifstream or std::ofstream directly (or their open() function) because their file systems are UTF-8 encoded, too.
Only for Windows it's a bit more difficult. For this platform std::ifstream or std::ofstream provide overloaded versions of the constructors and open() functions. One version that accepts a std::string or const char* and another version that accepts a std::wstring or const wchar_t.
In order to properly support unicode the std::wstring/wchar_t variants must be used.
Now to avoid that every time a std::ifstream/std::ofstream is used one has to deal with the platform differences the classes Base::ifstream and Base::ofstream has been added that require a Base::FileInfo for their constructors.
So, writing the line
Base::ifstream str(Base::FileInfo(myStdString), ...);
works for all supported platforms.
wandererfan
wmayer wrote: Sat Aug 20, 2022 2:01 pm git commit ff01905f0b should fix it.
Problem fixed before I even read the post! Thank you.
Haavard
Post by Haavard »
Awesome, thanks! :)
