wandererfan wrote: ↑Sat Oct 15, 2022 6:42 pm How about this?
- ProjectionStrategy = Single. Much the same as a regular section, except it uses a profile instead of a section plane. All projections are made according to the SectionNormal.
- ProjectionStrategy = Piecewise. Every segment in the profile generates a face in the result; Projections are based on profile segment normals.
- ProjectionStrategy = NoParallel. As Piecewise, except profile segments that are parallel with the SectionNormal are ignored. This would do your "several parallel offset sections" if the profile only contains vertical and horizontal segments.
I'm sorry, I meant "aligned section view"
I altered your image: I think we just need one Offset option (no parallel and no oblique to the normal) and one Aligned option (piecewise, only oblique and perpendicular to the normal ) and both shouldn't be mixed.
I hope this helps to clarify.
