Complex Sections
wandererfan
Re: Complex Sections
Post by wandererfan »
FBXL5 wrote: Sat Nov 12, 2022 11:53 pm If we have section line marks on complex sections they should also be found on simple sections. I have tried to aktivate them toggling the Section Line Marks property, but it neither aktivates mars for simple sections nor deactivates the marks of complex section.
Marks should be available on simple sections after git commit 26d7fe14e1
When you are toggling the marks, are you doing it on the base view or the section view? The setting in the BaseView is the one you need to change.
FBXL5
Post by FBXL5 »
wandererfan wrote: Wed Nov 16, 2022 2:12 pm The setting in the BaseView is the one you need to change.
Confirmed. I changed the property of the section view before. Hiding the marks in the BaseView of a complex section works as expected.
I'm waiting for the next weekly to check the simple sections.
NewJoker
Post by NewJoker »
I tried creating aligned section but it failed. Am I doing something wrong ?
Aligned.FCStd
(59.8 KiB) Downloaded 11 times
OS: Windows 10 Version 2009
Version: 0.21.31097 (Git)
Hash: ccf074008774f1bdfed8fec09ed60e2c0fe77cae
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Polish/Poland (pl_PL)
aapo
Post by aapo »
NewJoker wrote: Fri Nov 25, 2022 2:19 pm I tried creating aligned section but it failed. Am I doing something wrong ?
Yes. You're supposed to select the View and the Sketch and press ComplexSection button; you have selected the Body "PolarPattern" and the Sketch, which doesn't work.
EDIT: Wait, that isn't it. But doing the ComplexSection works fine for me, what did you actually select when making it?
Aligned-Fixed.FCStd
(61.51 KiB) Downloaded 15 times
NewJoker
Post by NewJoker »
aapo wrote: Fri Nov 25, 2022 3:34 pm Yes. You're supposed to select the View and the Sketch and press ComplexSection button; you have selected the Body "PolarPattern" and the Sketch, which doesn't work.
That's what I do - I select the sketch and the view but the latter is replaced with polar pattern after enabling the complex section tool. Perhaps it's just how it works (replaces view with corresponding 3D geometry) and the problem lies somewhere else.
aapo
Post by aapo »
NewJoker wrote: Fri Nov 25, 2022 3:41 pm That's what I do - I select the sketch and the view but the latter is replaced with polar pattern after enabling the complex section tool. Perhaps it's just how it works (replaces view with corresponding 3D geometry) and the problem lies somewhere else.
Yes, there's definitely something fishy going on here. The above file "Aligned-Fixed.FCStd" I just uploaded doesn't load correctly for me. It seems that the Aligned Section in your example sometimes works, and sometimes doesn't, and it doesn't seem to be really deterministic. :shock:
In addition, I get plenty of
18:07:08  Unhandled unknown exception caught in GUIApplication::notify.
in the report window when recalculating these Complex Sections. Definitely something to have a look at, thanks.
wandererfan
aapo wrote: Fri Nov 25, 2022 4:15 pm ...it doesn't seem to be really deterministic.
Same here. Works one time, doesn't work another time. I wonder if it is threading related?
wandererfan
On the advanced tab, there is an option for "Report progress". This generates messages as each threaded step is started and completed. That might give a clue.
NewJoker
Post by NewJoker »
wandererfan wrote: Fri Nov 25, 2022 5:26 pm On the advanced tab, there is an option for "Report progress". This generates messages as each threaded step is started and completed. That might give a clue.
Here's what I got from this:
Svg Hatch File: E:/FreeCAD_weekly-builds-27809-Win-Conda_vc14.x-x86_64/data/Mod/TechDraw/Patterns/simple.svg is not readable
Pat Hatch File: E:/FreeCAD_weekly-builds-27809-Win-Conda_vc14.x-x86_64/data/Mod/TechDraw/PAT/FCPAT.pat is not readable
Line Group File: E:/FreeCAD_weekly-builds-27809-Win-Conda_vc14.x-x86_64/data/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
ComplexSection has finished making section cut
wandererfan
NewJoker wrote: Fri Nov 25, 2022 6:15 pm E:/FreeCAD_weekly-builds-27809-Win-Conda_vc14.x-x86_64
27809 can't be the revision number, can it? That would put the build in Feb 2022, well before ComplexSection was added.
I haven't been able to recreate a fail with Aligned.FCStd since the first try. I've used local builds and "FreeCAD_weekly-builds-31097-2022-11-26-conda-Linux-x86_64-py310.AppImage".
I don't get the "is not readable" messages either. I thought those were fixed a long time ago.
Can this be a Windows only thing? I hope not, as I upgraded VirtualBox and now my Windows VM won't run FC. :(
