[FIXED] TechDraw hatching makes dimensions hide behind the view
aapo
Post by aapo »
Hi!
I believe I've likely encountered a new TD bug: TechDraw hatching makes dimensions hide behind the view. The problem happens, when the user adds a dimension overlapping a View, adding a geometrical hatch on the same face, saving file and closing FreeCAD. When reopening FreeCAD and reloading the file, the dimension goes "under" the View, at least sometimes. The dimensions are overdrawn in pdf export, too, not just the TD Qt view. See the picture below, and the example file, please.
20220923 TD-RenderBug p01.png (6.33 KiB) Viewed 789 times
OS: Windows 10 Version 2009
Version: 0.21.30398 (Git)
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Assembly4 0.12.4
  * Curves 0.5.8
  * Defeaturing 1.2.0
  * fasteners 0.4.6
  * FCGear 1.0.0
  * freecad.gears 1.0.0
  * Manipulator 1.4.9
  * Reinforcement
  * Render 2022.2.0
  * sheetmetal 0.2.57
  * ThreadProfile 1.83.0
  * toSketch 1.0.0
20220923 TD-RenderBug.FCStd
(23.54 KiB) Downloaded 24 times
wandererfan
Re: [BUG?] TechDraw hatching makes dimensions hide behind the view
Post by wandererfan »
aapo wrote: Fri Sep 23, 2022 9:35 am I believe I've likely encountered a new TD bug: TechDraw hatching makes dimensions hide behind the view.
In the short term, go to the PropertyEditor View tab for the dimension, RMB, then ShowAll and change Stack Order to some large number. 100 should do it.
A proper fix to the stacking order will be along shortly.
aapo
Post by aapo »
Thanks! :D
wandererfan
Should be fixed after git commit 74c1fed8a6. You may need to manually adjust the Stack Order after loading a saved file.
I had overlooked that dimensions(and balloons) need to stack within their parent view.
aapo
Post by aapo »
wandererfan wrote: Sat Sep 24, 2022 12:44 pm Should be fixed after git commit 74c1fed8a6. You may need to manually adjust the Stack Order after loading a saved file.
Confirmed fixed, everything works now as expected. Many thanks! :D
Version: 0.21.30454 (Git)
Hash: 5df954690787dedbbf3c35f658f010f388474676
Installed mods:
  * Assembly4 0.11.9
  * CurvedShapes 1.0.0
  * Curves 0.3.0
  * fasteners 0.3.38
  * fcgear
  * fcgear.bak
  * OpticsWorkbench 1.0.7
  * sheetmetal 0.2.49
