Techdraw Spreadsheet Tip
I don't know if this is a known issue but it is something I have just discovered while importing a spreadsheet view into my drawing:-
I had a line in my first column which read:-
M18x105 M8.8 bolts with nut & washers.
I had to change it to:-
M18 by 105mm M8.8 bolt with nut and washers.
The lesson seemingly that Techdraw will not accept spreadsheet fields that include operators such as x and &. It will throw an error in the area at the bottom of the combo view.
This is probably pretty obvious to more expert users but I had to figure it out through trial. error and a little bit of intuition.
Last edited by Laurie Hartley on Sun Oct 02, 2022 8:59 pm, edited 1 time in total.
- Shalmeneser
Re: Techdraw Spreadsheet Tip
Can you provide a minimal working example (MWE) ?
Yes - I am away from my computer but I will tomorrow.
Have you tried putting spaces between the numerical values, e.g. M 18 x 8.8?
And please add where in TechDraw you want to reference the spreadsheet's value.
@Shalmeneser - example as promised.
@rdinohio - yes see file - it doesn't appear to make a difference.
I don't think it is a big deal really but could cause some confusion for people who use my sort of terminology.
- Techdraw_Spreadsheet.FCStd
- (20.77 KiB) Downloaded 43 times
Confirmed, these characters need to be 'escaped' somehow.
Instead of & use: & or &
Instead of x use: x
Instead of x use: x
- Shalmeneser
'x' : no problem
'&' : problem
'Plate with 4 x 12mm Holes & 50 x 12mm slot' : problem -> nothing visible
'Plate with 4 x 12mm Holes + 50 x 12mm slot' : no problem -> everything visible
TechDraw_SpreadsheetView
(I don't know for 0.21 because SpreadSheet crash each time I click in a cell)
'&' : problem
OS: Windows 10 Version 1809
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: French/France (fr_FR)
Installed mods:
* fasteners 0.4.3
* fcgear 1.0.0
* Manipulator 1.4.9
* sheetmetal 0.2.56
- Shalmeneser
((KISS : keep it stupidly simple))
- Techdraw_Spreadsheet_SHALM.FCStd
- (27.11 KiB) Downloaded 31 times
Confirmed.
