Incorrectly oriented (rotated) section views
NewJoker
Post by NewJoker »
I've noticed that section views are incorrectly oriented (rotated) with respect to their corresponding views in 0.21 dev version.
Here's what it looks like in 0.20.1 stable:
section example 2.JPG (17.6 KiB) Viewed 1687 times
And here's what it looks like in 0.21 dev:
section example 1.JPG (18.88 KiB) Viewed 1687 times
I guess that this behavior is caused by changes introduced with the new Complex Section tool. I know that section views can be rotated but would it be possible to make their default orientation consistent with FreeCAD 0.20 ?
OS: Windows 10 Version 2009
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: Polish/Poland (pl_PL)
wandererfan
Re: Incorrectly oriented (rotated) section views
Post by wandererfan »
NewJoker wrote: Wed Dec 07, 2022 7:54 pm I guess that this behavior is caused by changes introduced with the new Complex Section tool. I know that section views can be rotated but would it be possible to make their default orientation consistent with FreeCAD 0.20 ?
@FBXL5 is teaching me about correct orientation of section views - https://www.forum.freecadweb.org/viewto ... 52#p646152 - so there might be some changes in this area soon.
Please post a file that exhibits the problem, as it doesn't show up in this trivial test:
NewJoker
Post by NewJoker »
wandererfan wrote: Wed Dec 07, 2022 9:05 pm Please post a file that exhibits the problem, as it doesn't show up in this trivial test:
Here's a file showing this problem:
section orientation.FCStd
(26.3 KiB) Downloaded 42 times
wandererfan
NewJoker wrote: Wed Dec 07, 2022 9:51 pm
I must be doing something wrong. I don't get any difference using your file with v.20 and v.21. My v0.20 is a snap version - I wonder if that is significant.
My versions:
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.21.0.31223 (Git)
Build type: Unknown
Hash: 9869a2c3d7bdacdfac605db318c73e3b2d71245c
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Installed mods:
  * FreeCAD_Electric
  * Assembly4 0.12.4
  * A2plus 0.4.56a
OS: Ubuntu Core 20 (X-Cinnamon/cinnamon)
Version: 0.20.1.29177 +233 (Git) Snap 245
Branch: tag: 0.20.1
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
My results...
NewJoker
Post by NewJoker »
wandererfan wrote: Fri Dec 09, 2022 12:25 am I must be doing something wrong. I don't get any difference using your file with v.20 and v.21. My v0.20 is a snap version - I wonder if that is significant.
Maybe it's because you are using Linux or a newer build. My colleague has the same issue with his model. He's also using the newest build available for Windows.
jpg87
Post by jpg87 »
Hello and thank you @wandererfan for the important work done with TechDraw.
I also noticed the same problem with the orientation of the sections :
Here is my version:
Locale: French/France (fr_FR)
Installed mods:
  * A2plusSavTraduc
  * Assembly3 0.11.4
  * BIM 2021.12.0
  * BOLTSFC
  * Curves 0.5.5
  * DynamicData 2.46.0
  * fasteners 0.4.2
  * fcgear 1.0.0
  * freecad.gears 1.0.0
  * IconThemes
  * PieMenu
  * QuickMeasure 2022.10.28
  * symbols_library
I tested the complex cuts: I must not have understood everything yet because my results are not always those expected!
I'll come back to the forum if I can't.
roue.FCStd
(160.84 KiB) Downloaded 34 times
My website : http://help-freecad-jpg87.fr updated 2023/11/06
user1234
Post by user1234 »
@NewJoker
@jpg87
see @wandererfan PR7972, https://github.com/FreeCAD/FreeCAD/pull/7972, seems to work, see https://forum.freecadweb.org/viewtopic. ... 40#p646576
Greetings
user1234
jpg87
Post by jpg87 »
@user1234 Thanks for the info, but I'm only using the released updates, and the latest one, released yesterday, doesn't have the fix yet.
The same file produces the same error, but I noticed that the error does not occur if the section plane is horizontal.
Installed mods:
  * A2plusSavTraduc
  * Assembly3 0.11.4
  * BIM 2021.12.0
  * BOLTSFC
  * Curves 0.5.5
  * fasteners 0.4.2
  * fcgear 1.0.0
  * IconThemes
  * PieMenu
  * symbols_library
NewJoker
Post by NewJoker »
@user1234 Then I will tests it once this PR is merged and included in Windows build. But it’s for the new Complex Section tool so I’m not sure if it can also fix the behavior occuring with standard section.
wandererfan
Well, I don't know what is going on. I tested 3 different versions on Windows and they all produced the same section view - the one with the section view "lying flat". :?
The PR version produces a new or edited view with the section view "lying upright", but the untouched view is still "lying flat".
I'll try downloading the current stable v0.20 and current Appimage v0.21 later today.
Your version:
The 3 versions I tried...
Local build:
Version: 0.21.0.31284 (Git)
Branch: invSectionRotation
Hash: b4bd8d9f6c2bde1e6b1d342671cee4c01d043c20
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk , OCC 7.6.3
Older AppImage for v021
Version: 0.21.31097 (Git)
Hash: ccf074008774f1bdfed8fec09ed60e2c0fe77cae
Older v0.20 downloads:
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
