Sketcher tutorial
A place to share learning material: written tutorials, videos, etc.
abdullah
Re: Sketcher tutorial
Postby abdullah » Mon Jan 07, 2019 10:03 am
robcad wrote:
Mon Dec 31, 2018 7:22 pm
And here is how it does not work under certain conditions.
chrisb wrote:
Thu Jan 03, 2019 1:28 am
I have no idea what's going on, I haven't ever seen this error message. Abdullah, can you help?
Hi there! Sorry for the long absence.
I think the problem might be the "rendering order" in the "Edit Controls".
The error message is telling you that the point that you are selecting is not connected to an edge. This is because what is selected is the center of the endpole, which is at the same location as the endpoint of the bspline.
When there are co-located points, the point that is selected, generally depends on which object was created first, and thus is rendered first, unless one of the specific rules of the "rendering order" applies.
You may remember that the original B-Spline creation introduced the circles of the poles AFTER the B-Spline. Then you always had to use the work-around of using the Element's widget. Then the creation was rewritten some six months ago to introduce the circles of the poles BEFORE the B-Spline. This allowed that, with the "normal" rendering order, the endpoints are selected and it is way more usable. However, if one changes the order to "construction" geometry first, then you will select the center of the construction circle of the pole.
Postby chrisb » Mon Jan 07, 2019 6:29 pm
Thanks for this excellent explanation, I'm glad that nothing is broken. Alas, it means I have to add this to my tutorial.
abdullah
Postby abdullah » Tue Jan 08, 2019 12:46 pm
Welcome! I use each opportunity to give you extra work :mrgreen: :lol: :lol: :lol:
robcad
Postby robcad » Tue Jan 08, 2019 8:37 pm
Thanks, yes this is the "problem".
B-Spline_Exercise_16 + Rendering Order.gif (413.47 KiB) Viewed 1002 times
B-Spline_Exercise_16.fcstd
(6.12 KiB) Downloaded 31 times
(1) What is the default setting of "Rendering order"?
(2) Is there an other way to have a choice between Vertex1 and Vertex6?
(3) Is there a way to see that Vertex6 is the endpoint of the spline?
Postby chrisb » Tue Jan 08, 2019 10:14 pm
Good to see that it works.
In the Elements section in the Sketcher panel you can switch the type from "Edge" to "Starting point" or "End point". When you now select an element in the list (not in 3D view!) than the corresponding start point or endpoint is selected.
abdullah
Postby abdullah » Wed Jan 09, 2019 12:39 pm
The current FC daily from the PPA:
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15592 (Git)
Hash: a7c0f4bc5b62ec304a5855796ca3d10a42c7a46e
Python version: 2.7.15rc1
Qt version: 5.9.5
"Silently" dies when I try to load your file (and not only yours):
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7fd388302f20]
corrupted double-linked list
when trying to load one file, so I cannot check my answers:
(1) Normal, Construction, External
(2) Element's widget. Check the "extended naming" checkbox if unchecked.
(3) Iterate one Element's "edge","startpoint","endpoint","center" by pressing 'z' while you hover the element in the elements widget. The preselection will mark the part of the element in yellow on the 3D view. Alternatively, you may use the selection drop box as Chris says.
abdullah
Postby abdullah » Wed Jan 09, 2019 1:04 pm
The crash should be solved, as this self-compiled version does not crash:
Version: 0.18.15596 +1 (Git)
Build type: DEBUG
Branch: _geometry_extension_
Hash: ac7b387f781fff45163c13b5543cbc108bc40ebc
Python version: 3.6.7
Qt version: 5.9.5
robcad
Postby robcad » Wed Jan 09, 2019 7:06 pm
Using "Z"-Key while hover the element:
B-Spline_Exercise_16 + Z-Key.gif (371.45 KiB) Viewed 930 times
(6.13 KiB) Downloaded 33 times
Nice way to work. Thanks.
jrdrukin
Postby jrdrukin » Fri Jan 18, 2019 4:01 pm
chrisb,
I just spent few minutes re-reading it.
Every time I read your Sketcher Tutorial I learn and/or reinforce
important concepts necessary for 3d modeling and FC.
Thank you very much for your considerable time and effort!
Your work is greatly appreciated! :)
Jerry/jrdrukin
jrdrukin
Postby jrdrukin » Fri Jan 18, 2019 4:19 pm
chrisb,
Maybe add DOF's for the conics and b-splines to your table on pp.74?
