Page 2 of 4
Re: Tutorial : Introduction to mechanical engineering with FreeCAD
Posted: Mon Aug 27, 2018 9:46 am
by jpg87
Posted: Mon Aug 27, 2018 10:15 am
by chrisb
Off topic here, but it was discussed concerning animated gifs vs. video.
The link shows wonderful usage for animated gifs, that's what they are made for. But mostly not for tutorial usage.
Posted: Mon Aug 27, 2018 11:02 am
by realthunder
jpg87 wrote: ↑Mon Aug 27, 2018 9:46 am
Two new pages have been added for assemblies:
About the PointOnLine constraint, with recent versions of asm3, the normal of a plane and the revolving axis of cylindrical surface can both be used as a 'Line'. In other word, for the second element of a PointOnLine constraint, you can simply use a cylindrical face, or the circular edge of the cylindrical face, or the circular edge of the sketch that creates the groove, and there is no need for an auxiliary sketch or manual setting of an offset.
Posted: Mon Aug 27, 2018 6:09 pm
by jpg87
chrisb wrote: ↑Mon Aug 27, 2018 10:15 am
As soon as I've developed a technique, I'll replace some gif images with small videos (hopefully!).
But if you've had a look at the animations in the PartDesign examples, they'll only play once when the mouse over the image, they do not see themselves at rest, and they are slow. This is not enough but ...
Posted: Mon Aug 27, 2018 6:12 pm
by jpg87
realthunder wrote: ↑Mon Aug 27, 2018 11:02 am
OK, it's rectified. I did not have time to test the latest updates !
Posted: Sat Sep 08, 2018 4:35 pm
by jpg87
Example 4 (wheel) has been updated with Webm videos.
- wheel.png (59.61 KiB) Viewed 3172 times
More videos will be added for the first examples.
Posted: Fri Oct 05, 2018 5:45 pm
by jpg87
Videos have been added to all current examples.
Next goal: simple assemblies.
Posted: Sat Jan 04, 2020 10:31 pm
by mikelihue
Excellent tutorial, JPG.... Very well laid out, nice flow to the presentation, and fabulous animated diagrams. I also learned that "soustractive is french for "subtractive". I thought it was a recurring typo at first, then I finally determined that it was French.
This is a beautifully designed intro to FreeCAD. Thank you for putting in the time to develop this.
Posted: Tue Jan 14, 2020 5:59 pm
by jpg87
mikelihue wrote: ↑Sat Jan 04, 2020 10:31 pm
by mikelihue » Sat Jan 04, 2020 11:31 pm
Thank you very much for these comments.
Hello everyone.
After an absence from the forum for more than a year, I am pleased to inform you of the update of my site concerning the chapter "assemblies" with Asm3 WB :
- Struct_ass_camionnette.png (86.94 KiB) Viewed 2541 times
Posted: Thu Feb 27, 2020 12:55 am
by YRabbit
Hello,
Can I download the sources of this assembly (
1st example : using sub-object shape binder) somewhere? I ask because when I add a sub-object shape binder, the document can no longer be saved because here I get a loop in dependencies. So I'm interested in figuring out what I'm doing wrong
