I'm having trouble with videos on the forum, both posted by others and the ones I try to post.
Videos hosted on youtube work reliably.
Videos hosted elsewhere (github, dropbox, etc) often fail to play with one of two messages:
"No Video with supported format and MIME type found"
"Sorry this URL is not supported"
Other times I get a black box with no messages.
I've tried with Firefox and Chromium. Same results.
I can create videos locally (webm and mp4) and they play every time.
Any guesses? Things to check further? Security settings?
FreeCAD info
OS: Linux Mint 19 Tara
Version: 0.18.15363 (Git)
Hash: 9be3e633328335f1172456f5857219b7a08c70a5
Python version: 2.7.15rc1
Help with viewing (and creating) videos
- wandererfan
Re: Help with viewing (and creating) videos
The trick to getting the video hosted on github to play on the forum is get the link to the raw file, not the link to the file where you see it in the listing. Select view raw or something similar and post that url inside the video tags. I have written this python script for automating this process for me:wandererfan wrote: ↑Mon Dec 10, 2018 3:06 pm I'm having trouble with videos on the forum, both posted by others and the ones I try to post.
FreeCAD info
import sys, os
import subprocess
"""This is a way for me to generate the url needed for posting the videos to the
FreeCAD forum boards. In Windows 10 Explorer I'm able to drag and drop the webm video to
this file, which then creates the url and video tags string, and then copies it to the clipboard.
This greatly improves things because now I don't have to go to github.com each time to get the url.
def modifyThineSelf():
"""This is just to modify the file so it appears at the top of the folder when sorting by modified date."""
fin = open(__file__, 'r')
code = fin.read()
fin.close()
fout = open(__file__, 'w')
fout.write(code)
fout.close()
def copy2clip(txt):
cmd='echo '+txt.strip()+'|clip'
return subprocess.check_call(cmd, shell=True)
prepend = "https://raw.githubusercontent.com/mwganson/FreeCAD-videos/master/"
if len(sys.argv) != 2:
input("Please drag and drop a file or enter filename as command line parameter")
else:
modifyThineSelf()
fileName = os.path.basename(sys.argv[1])
data = "[video]" + prepend + fileName + "[/video]"
copy2clip(data)
#Following could be removed as it only pauses the screen and displays the confirmation
text = input(data + " has been copied to clipboard (press enter to close) ")
git add .
git commit -m"message"
git push
This I have also automated in another script.
I have checked github's terms of service and I see nothing in it that forbids using it in this manner. Certainly, if the videos (all documenting FreeCAD) were in the FreeCAD repository github would have no complaint. It can be argued my video repository is an extension of FreeCAD and acting as extended documentation. That would be my argument to them if they told me something.
