Tutorial to prepare a part to generate gcode
A place to share learning material: written tutorials, videos, etc.
roerich_64
Postby roerich_64 » Sun May 19, 2019 3:39 pm
Hi to all,
Based on this pictures i will show you the workflow to prepare a part to generate gcode for 2.5D and i think others who reading this helps it:
WCS = Work-Coordinate-System
Let us have a look to where we can found these Coordinate-Systems in Freecad:
When we set the WCS: Z=0 at the top of the part then the post processor generates g Code with -Z values. So the spindle steps down to engrave it.
@Sliptonic gave us a nice tool (Setup) to take the Model-body to the right place:
1. Click on the top of the body
2. take Z-Axis
3. take Z=0. The Model-Body flips down
4. You have to refresh the stock.
Now let us take a look what we now see:
This is the startpoint to generate the gcode with 2.5D operations ;)
BR
Walter
roerich_64
Re: Tutorial to prepare a part to generate gcode
Postby roerich_64 » Sun May 19, 2019 4:15 pm
Ok.
Let us have a look to a real part, how we can need the above procedure.
It is a rolling container for sorting parts:
In FreeCAD:
When it is ready prepared, than it looks so:
I think the best way for now is, i make a video.
But, when it is needed, i can also do a step-by-step turorial here ;-)
BR
Walter
sliptonic
Postby sliptonic » Sun May 19, 2019 6:00 pm
Hi Walter,
Nice pictures and a good tutorial. Keep it up!
One clarification however; FreeCAD has no knowledge of the Machine Coordinate System (MCS) at all. We ONLY work with the WCS. What you show in the second picture of the first post is the default placement of the body. It will be used as the default origin for the WCS when the job is set up. The origin of the job can, as you show, be moved.
Machine controllers like LinuxCNC keep track of both and are able to visualize the WCS within the real work envelope of the machine. But FreeCAD doesn't know anything about the machine's origin or work envelope. Since it doesn't know about those things, it can't know about the relationship between job origin and the machine origin.
roerich_64
Postby roerich_64 » Sun May 19, 2019 8:23 pm
Hi @Sliptonic,
thank you for the additional explanation :-)
Yes i am with you and will correct it ;-)
Edit: and now corrected.
Walter
roerich_64
Postby roerich_64 » Wed May 22, 2019 11:19 pm
At first i will show you how we can generate the container frame:
To do that we need the boxCreator-Macro. We found them with 'Tools / Addonmanager' then with the TAB 'Macros':
1. Click the TAB 'Macros' in AddonManager and scroll down to 'BoxCreator'.
2. Select them with a 'click' and take 'Install / update'
Now we have to create a new File.
After them we can start the macro 'BoxCreator' when we take the TAB 'Macro' and then take 'Macros...':
It opens the window 'start Macro':
1. Select with a click the 'BoxCreator.FCMacro'
2. then take 'Start' (in German: Ausführen -) )
roerich_64
Postby roerich_64 » Fri May 31, 2019 10:17 pm
Ok, for now the 'box creator-macro' works with Py2 / Qt4 ;-)
Another thanks to @Christi from here!
The Boxcreator-Forum:
https://forum.freecadweb.org/viewtopic. ... 10#p311162
And here my System with which i do the next steps:
OS: Windows 7
Version: 0.19.16274 (Git)
Hash: 7c760259a389b38b76da78e4f6e1f9be66714842
Python version: 2.7.14
OCC version: 7.2.0
So, we have installed the box creator-macro as above and we will create a container under the desk to sort parts:
Dimensions for my Container: W: 475mm, H: 650mm, L: 600mm.
Thickness of the material: 9mm
Overhang in the front for the dazzle: 19mm
roerich_64
Postby roerich_64 » Mon Jun 03, 2019 9:47 pm
The next step is to delete the 'box':
Select the 'Box' and delete them with 'DEL' on the keyboard.
Now we see this:
To see how i can place the walls of the container on the CNC i have create a sketch with the dimensions of my machine:
Result:
roerich_64
Postby roerich_64 » Tue Jun 04, 2019 4:53 pm
Next steps:
1. Select the Path-WB
2. Create the job
We select the parts and click 'OK':
Now we are in the 'Setup' and we can do the positioning of the walls:
Click in the canvas on the Top of the first part (bottom)
Click 'Z-Axis'
Click 'Z=0'
The part 'bottom' flips down. We have Z=0 at his top ;-)
Next:
- Click the inner side of the left wall to define on which surface should be the Z-vector.
- Click 'Z-Axis'
- Click 'Z=0'
Result:
