Hi everyone! I intended to learn FreeCAD by doing the basic which is starting with the tutorial particularly "Creating a simple part with PartDesign".
https://wiki.freecadweb.org/Creating_a_ ... PartDesign
It may seem so basic as it seems, but I couldn't move on due to the following problems I encountered below:
1. I presume that when the dot turns yellow, it snaps perfectly to the origin (0,0). But even at (-1,-1) it's still yellow, is there setting for perfect snapping on the desired coordinates?
2. I don't see a red dot but a red line beside the mouse pointer, what should I do?
3. After making a line, the instruction says I need the Select tool. But the mouse pointer is still making a Line tool, how can I exit?
4. How to lock drawing a line in horizontal or vertical lines? Are there any keyboard shortcuts to do that?
5. After creating the sketch, I don't see any horizontal, vertical, angle constraint red symbols on the segments, how come?
I would really appreciate your help!
Cheers!
A newbie asking for help and guidance
Re: A newbie asking for help and guidance
Press Escape key once, or the right mouse button once.
Check the main page, Sketcher Workbench, and read quickly the description for all the tools. You "lock" the lines using the vertical and horizontal constraints.4. How to lock drawing a line in horizontal or vertical lines? Are there any keyboard shortcuts to do that?
The sketch's task panel should have options to set up the grid snapping and automatic constraints.5. After creating the sketch, I don't see any horizontal, vertical, angle constraint red symbols on the segments, how come?
In the paragraph named "Create sketch:" the preliminary setup of Sketcher is shown.
Please note that the grid is only an editing aid, it does not create any locking on the grid. That has to be done with constranits.
And please note that all non-auto constraints are added later.
