bluecfd installation guide
A place to share learning material: written tutorials, videos, etc.
thschrader
Post by thschrader »
I wrote a little help for first time user of bluecfd / cfdof-workbench.
Hope that helps. comments welcome.
Keep on foaming... :)
Installing bluecfd for Windows 10 and FreeCAD.pdf
(541.02 KiB) Downloaded 413 times
EDIT 20.06.2021:
Upgrade from bluecfd 2017 to bluecfd 2020, please see here
https://forum.freecadweb.org/viewtopic.php?f=37&t=59537
Re: bluecfd installation guide
Is there a better place to keep this information so it won't get lost? Perhaps the videos and tutorials section?
thschrader
Chris, can you move it to tutorials?
Done. I have left a shadow in the old place. I did that for the first time, and I wasn't sure what would happen; it left a link to the tutorials topic.
sgrogan
Post by sgrogan »
thschrader wrote: Sat Nov 21, 2020 10:06 am Hope that helps. comments welcome.
This is quite awesome.
Do you have any clue why the Conda based build doesn't work?
"fight the good fight"
thschrader
Sorry, no idea. Only trial and error... ;)
Syres
Post by Syres »
sgrogan wrote: Sat Nov 21, 2020 1:05 pm Do you have any clue why the Conda based build doesn't work?
I'll have a look tonight through tomorrow and try to get a definitive answer with my setup (which isn't exactly the same as Thomas has documented) but there have been quite a few changes to the Cfd-OF Wb recently which did give me a headache with my macros I use for crude bench marking. We need to send @oliveroxtoby on holiday for a while :lol: (he does fine work, I just struggle to keep up sometimes).
Syres
Post by Syres »
thschrader wrote: Sat Nov 21, 2020 1:48 pm Sorry, no idea. Only trial and error... ;)
Could you please look at the following blueCFD version info from Control Panel and confirm that you have the exact same version, I'm not getting any errors using the latest Conda build other than gmsh (which isn't build specific) and my bench marking macros are successful at solving the Millennium Falcon in 182 iterations which is as expected.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.23058 (Git)
Hash: 6e60870ebcb2df018adb7a1281c00dde87750f11
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
thschrader
Syres wrote: Sat Nov 21, 2020 5:49 pm ...
Aaah...I am not sure which version.
Our IT-service installed bluecfd last year on my Laptop.
I gave the IT-service the advice to use the bluecfd.github.io...
not bluecape.
https://joomla.bluecape.com.pt/index.ph ... =2&lang=en
http://bluecfd.github.io/Core/Downloads/
But the versions should be the same. Right? Should be...
Man, I am confused.
Greetings Thomas
thschrader
the fs dynamics installation link directs me to bluecfd github. there should be no difference. at the moment
only 1 user reported a problem with conda.
lets wait what other users say...
i will correct my guide next week.
