Arch Workbench - Parametric Window placement
A place to share learning material: written tutorials, videos, etc.
vondav
Post by vondav »
A few weeks ago I tried parametric window placement in Arch Workbench and found how to do it. And finally I made a short video about it.
https://youtu.be/suBZidln_jg
phpBB [video]
Roy_043
Re: Arch Workbench - Parametric Window placement
Post by Roy_043 »
There are some problems with the proposed workflow. For one thing you are attaching a sketch to the face of the wall. This is not a good idea.
See:
Feature_editing
Topological_naming_problem
Also:
Using attachments you can place the base sketch of the window in relation to the base sketch of the wall. This would be more stable and efficient.
vondav
Post by vondav »
Roy_043 wrote: Fri Jun 04, 2021 8:40 am There are some problems with the proposed workflow. For one thing you are attaching a sketch to the face of the wall. This is not a good idea.
You are right, my mistake (I'm usually using RealThunder Assembly3)
Could You show me details, how can it be done, please?
Roy_043
Post by Roy_043 »
There is still an issue with the normal of the window. The default (0,0,0) results in an inverted extrusion.
Further reading:
https://forum.freecadweb.org/viewtopic.php?f=23&t=39760
window-sketch-attached-to-wall-sketch.FCStd
(27.88 KiB) Downloaded 115 times
Pauvres_honteux
Post by Pauvres_honteux »
How about this workflow?
  • First make a new document and name it Layout_master.
  • Then make a Part.
  • Then create a master sketch on Parts XY-plane.
  • Then make planes passing through each centerline representing a wall center. Save and close document.
  • Create a new document and make a Part in it. Name the document Wall_North.fcstd. Link Layout_master into this new document. Create holes for windows using the previously created center planes as attachments.
  • Repeat for all walls.
  • Use your favorite Assembly workbench and put all together, and Bob's your uncle!
Done with:
OS: openSUSE Leap 15.2 (KDE//usr/share/xsessions/default)
Version: 0.20.24992 (Git) AppImage
Hash: 9332e52d944c1339e3b9a1b5a72dc6edc6d077a8
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
Layout_master.FCStd
(15.18 KiB) Downloaded 102 times
paullee
Post by paullee »
vondav
Post by vondav »
Roy_043 wrote: Fri Jun 04, 2021 11:58 am There is still an issue with the normal of the window. The default (0,0,0) results in an inverted extrusion.
Thanks, but this solution has problem that hole in the wall will not move if you change window position?
vondav
Post by vondav »
paullee wrote: Fri Jun 04, 2021 5:07 pm Alternative?
Intuitive Automatic Windows/Doors + Equipment Placement
Thanks, I'll take a look
Roy_043
Post by Roy_043 »
vondav wrote: Mon Jun 07, 2021 8:05 am Thanks, but this solution has problem that hole in the wall will not move if you change window position?
You have to recompute the wall.
vondav
Post by vondav »
Roy_043 wrote: Mon Jun 07, 2021 11:14 am You have to recompute the wall.
OK, it helps
