https://www.youtube.com/watch?v=gq8PrKt_1VY
belt drive calculation tutorial. center distance, belt tensioner, construction of a wave.
- thomas-neemann
Last edited by thomas-neemann on Thu Jan 20, 2022 11:52 am, edited 3 times in total.
Re: belt drive calculation tutorial. center distance, mechanical engineering.
Are you aware of the Roller Chain Parametric Design (old I know but still appears to work)? https://forum.freecadweb.org/viewtopic.php?t=18267
- thomas-neemann
thanks for the hint. I did not know. it works on the same principle. MarvelousSyres wrote: ↑Fri Aug 13, 2021 9:30 am Are you aware of the Roller Chain Parametric Design (old I know but still appears to work)? https://forum.freecadweb.org/viewtopic.php?t=18267
- thomas-neemann
belt tensioner
https://www.youtube.com/watch?v=DLU-MQSlVUg
edit
Online freecad support monthly for 450 euro
https://forum.freecadweb.org/viewtopic.php?f=31&t=65108
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.27078 (Git) AppImage
Branch: (HEAD detached at bcdd926)
Hash: bcdd926686f2245fe60baface1cce1ab3dff7a5b
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
edit
Qt version: 5.12.9
OCC version: 7.5.3
- thomas-neemann
Re: belt drive calculation tutorial. center distance, belt tensioner, engineering.
https://www.youtube.com/watch?v=OakSI3hjBzU
Qt version: 5.12.9
OCC version: 7.5.3
Qt version: 5.12.9
OCC version: 7.5.3
- thomas-neemann
Re: belt drive calculation tutorial. center distance, belt tensioner, construction of a wave.
With double pulleys I presume you are transferring lots of power, typically a tensioner is designed so that it tightens the belts on the pulley, this design kind of does the opposite. Tensioners are also placed on the slack side. Just thought I would bring it up.
- thomas-neemann
thanks for the information. the original construction is not mine. I prefer moveable wavesfreedman wrote: ↑Wed Mar 16, 2022 8:01 am With double pulleys I presume you are transferring lots of power, typically a tensioner is designed so that it tightens the belts on the pulley, this design kind of does the opposite. Tensioners are also placed on the slack side. Just thought I would bring it up.
