Architecture designs, concepts and demonstrations, IFC
- thomas-neemann
Last edited by thomas-neemann on Sun Jun 12, 2022 4:13 am, edited 5 times in total.
- thomas-neemann
- thomas-neemann
- thomas-neemann
- thomas-neemann
- ragohix769
Re: Architecture spiral driveway, design with freeform surface, concept etc
Here this is REALLY cool stuff Thomas. A little bit to quickly (I have to made 0,2 velocity play to understand). I like the way you use single line to create a 3D wood joist, then duplicate and move all, amazing.thomas-neemann wrote: ↑Mon Oct 04, 2021 12:54 pm concept of a winter garden
https://www.youtube.com/watch?v=7qJ13-7eTBM
[and the Shadows, I think it's fantastic to work with, it helps you on editing in this kind of workflow, really missing in FC official]
I still don't understand some basics about draft 3D, as grouping an remove some line in the group, but I'm studying it
Thanks again for your videos as usual, very useful.
[maybe you can change the subject topic with a more, general, clear name]
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
- thomas-neemann
thanks for the flowers, I changed the theme.
grouping works well with part compount or draft upgrade. dismantling goes well with draft downgrade
- ragohix769
Thank you for sharing!
Yes I know. But if I want to remove some line of two block made one block, I found this tricky. Anyway, I have to study a lot more Draftgrouping works well with part compount or draft upgrade. dismantling goes well with draft downgrade
- thomas-neemann
i also had problems at the beginning, now after more than 3000 hours of freecad it works fine
- thomas-neemann
Re: Architecture designs and concepts
concept a bridge
https://www.youtube.com/watch?v=6GaU_ZLlU8Y
edit
beach bar
https://www.youtube.com/watch?v=cIkXOCt8g4k
edit
beach bar
