IFC Master File, workaround for ifc not opening directly. example of the construction of lines in a bim process
A place to share learning material: written tutorials, videos, etc.
thomas-neemann
Post by thomas-neemann »
In this video you can see what an ifc master file is
https://www.youtube.com/watch?v=uh6q32-jl4U
phpBB [video]
edit
https://www.youtube.com/watch?v=D2K0IEr-5mk
phpBB [video]
Last edited by thomas-neemann on Sat Jun 11, 2022 5:04 am, edited 1 time in total.
doia
Re: IFC Master File
Post by doia »
Interesting.
So how would you translate that to FreeCad? How would I start if I have different stakeholders to a project each with their own model and have to connect/coordinate them using FC?
Would be nice to have conceptual write up of the possible approaches to this problem.
thomas-neemann
Re: IFC Master File
doia wrote: Sat Sep 11, 2021 8:08 am
I could create an example workflow in the form of video and link it here
thomas-neemann
Re: IFC Master File
doia wrote: Sat Sep 11, 2021 8:08 am ... using FC?
here is an example with freecad
https://www.youtube.com/watch?v=VIv-tFIzbcU
phpBB [video]
thomas-neemann
Re: IFC Master File
part 2. the dimensions of the structural engineer are built into the model by the architect.
https://www.youtube.com/watch?v=LmRSCHieZUg
phpBB [video]
ebrahim raeyat
Re: IFC Master File
Post by ebrahim raeyat »
thomas-neemann wrote: Fri Sep 10, 2021 7:52 pm In this video you can see what an ifc master file is
This application is very fantastic, the ideas is very good. is it open source?
Thanks a lot.
thomas-neemann
Re: IFC Master File
ebrahim raeyat wrote: Mon Sep 13, 2021 7:50 am
no it is not open source. but it's all about the workflow. everything is also possible with freecad
ebrahim raeyat
Re: IFC Master File
thomas-neemann wrote: Mon Sep 13, 2021 7:56 am
Thanks, Can we do the same things in FreeCAD?! Can you show how we can? I saw your videos for FreeCAD, but it is difficult to do it in FreeCAD, isn't it?
thomas-neemann
Re: IFC Master File
ebrahim raeyat wrote: Mon Sep 13, 2021 8:01 am
as long as you only work with geometry, everything is very easy. it gets tedious when attributes are to be used.
thomas-neemann
Re: IFC Master File
https://www.youtube.com/watch?v=0ALqIoJFXA0
phpBB [video]
