FreeCAD Basic Tutorial For Bad User (Beginner & Pro Not Recommend)
A place to share learning material: written tutorials, videos, etc.
mufasu
Re: FreeCAD Basic Tutorial For Beginner Exercise
Post by mufasu »
Shalmeneser wrote: Wed Oct 13, 2021 7:21 pm (Problems with fillet in my file)
This also the big problem fillet,,, when i use the faster ways to create object,, i cant do fillet on edge. but if i use different way the fillet command is working on edge :lol: . i just pick the ways for the final result as the object should be
mufasu
Re: FreeCAD Basic Tutorial For Bad User (Beginner & Pro Not Recommend)
Post by mufasu »
update exercise 21
phpBB [video]
Shalmeneser
Post by Shalmeneser »
2:30 Selecting a face to support a sketch is prone to TNP => select a plane, moreover for something like a ThroughAll Hole.
5:20 You kill PolarPattern, you kill PARAMETRIC. :o
So if you change something in the tree construction, it will crash or not follow :(
mufasu
Post by mufasu »
Shalmeneser wrote: Thu Oct 21, 2021 4:03 pm 2:30 Selecting a face to support a sketch is prone to TNP => select a plane, moreover for something like a ThroughAll Hole.
Thats my style :D,, As long as the dimensions don't change, it doesn't matter for me. Still get the good part for 3d printing
selecting a face to support a sketch its a features on cad sofware,, if you already try the others cad software like fusion 360, zw3d, solidworks, inventor, autocad mechanical, creo, corelcad, rhino, gstarcad, solidedge, progecad, catia, and gstarcad mechanical. its doesn't matter to do that, because its just a feature to speed drawing than you create a dantum plan then drawing. And freecad allow to selecting face to create sketch :D.
mufasu
Post by mufasu »
Today for bad practice on freecad how to create walker clamp
phpBB [video]
mufasu wrote: Sun Jan 09, 2022 10:58 pm Today for bad practice on freecad how to create walker clamp
Bad practice indeed, but you should name it, so that others can learn.
E.g.:
- Better think of where you center an object
- prefer geometric constraints over dimensions
- use the famous M key with polyline tool
Shalmeneser
* Symmetry ?
* Equality ?
* Geometric over Dimensionnal constraints ?
* Polyline ?
* Sheet metal (for future unfolding) ?
* Slot ?
* Datum plane ?
* Normal to Edge attachment ?
*Fastener wb thread ?
* Hand assembly ?
* No expression / reference ?
* Youtube comments dissappear ?
* Parametric ?
mufasu
Post by mufasu »
New Exercise 41
phpBB [video]
Shalmeneser
* Symmetry with axis ?
* TNP TNP TNP !
Mufasu 41.FCStd
(411.58 KiB) Downloaded 35 times
Capture du 2022-04-19 22-19-27.png (26.79 KiB) Viewed 2073 times
Shalmeneser
:idea:
Capture d’écran 2022-05-07 195530.jpg (28.5 KiB) Viewed 1830 times
Mufasu 43.FCStd
(83.99 KiB) Downloaded 27 times
Capture d’écran 2022-05-07 195327.jpg (81.39 KiB) Viewed 1830 times
